Ball vs valve type hose kit for hydraulic top link. How to know which one to choose
   / Ball vs valve type hose kit for hydraulic top link. How to know which one to choose #1
speedygun
2020 Mahindra 6075
Looking at purchasing a Cat 2 hydraulic top link for my Mahindra 6075, but not sure which type hose kit to get. Any help would be great
   / Ball vs valve type hose kit for hydraulic top link. How to know which one to choose #2
I am not sure what you are asking in your title.
You need hoses that will have correct fittings for your top link connections, and correct couplers for the SVC you connect to.
   / Ball vs valve type hose kit for hydraulic top link. How to know which one to choose #3
Look for any numbers stamped on the couplers you want to match to.
   / Ball vs valve type hose kit for hydraulic top link. How to know which one to choose #4
Either type will work, best to match what you have on the female end though. Just look down in the female end and see if there is a ball in the center or a nipple. I believe that it is a nipple.
   / Ball vs valve type hose kit for hydraulic top link. How to know which one to choose #5
Did you mean ball or "poppet" for the male tip?
   / Ball vs valve type hose kit for hydraulic top link. How to know which one to choose #6
I meant ball or poppet. People not familiar may not know what a poppet end is though. :unsure:
   / Ball vs valve type hose kit for hydraulic top link. How to know which one to choose #7
What did you end up with? I have the same tractor and I have a had a hard time finding info on a top and tilt kit for this tractor.
   / Ball vs valve type hose kit for hydraulic top link. How to know which one to choose #8
If you want a complete top & tilt set, I can build it for you.
I doubt that you will find any off the shelf sets for your application.
You can probably find an off the shelf top link that will work, but not ideal for your application.
Take a look at this link, get the asked for dimension and find a working length with the asked for dimension close to the extended length half way if you decide to get an off the shelf top link.
E-Z Trail Head Cart (A50514)
E-Z Trail Head...
BHARAT ENTERPRISES PARVEEN ALL PURPOSE PLOW (A51243)
BHARAT ENTERPRISES...
2023 CATERPILLAR 236D3 WHEELED SKID STEER (A51242)
2023 CATERPILLAR...
(2) Oliver Wheel Weights (A50515)
(2) Oliver Wheel...
12 ft Chisel Plow with Rolling Baskets (A52128)
12 ft Chisel Plow...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
