Trying to remove 50 inch oak tree stump with Bobcat backhoe. Struggling
   / Trying to remove 50 inch oak tree stump with Bobcat backhoe. Struggling #1
clydesdale
I screwed up and did not tell the tree guy to leave me a 4 foot stump. He cut it low. So, here I am. This thing grew on a rock ledge. I have trenched around it, but I can't get it to budge. Any suggestions? Burn it?
   / Trying to remove 50 inch oak tree stump with Bobcat backhoe. Struggling #2
drill holes, fill with diesel, couple bags of charcoal and a big bucket to cook it over a couple days
   / Trying to remove 50 inch oak tree stump with Bobcat backhoe. Struggling #4
You want a minimum CAT420 sized backhoe, a 20ton excavator preferred to yank out that puppy. Oak roots go deep.
You need to dig way deeper than you have gone so far.
   / Trying to remove 50 inch oak tree stump with Bobcat backhoe. Struggling #5
Burn it. Those rocks look pretty large.
   / Trying to remove 50 inch oak tree stump with Bobcat backhoe. Struggling #6
That's a tough one for sure. I had to cut down a dead oak that grew up on a rock pile and it was a mess. There were rocks INSIDE the tree that the tree grew around.
   / Trying to remove 50 inch oak tree stump with Bobcat backhoe. Struggling #7
Four foot above ground wouldn't have helped.
If for some reason you can't or don't want to burn it, cut it as low as you can below ground level and bury it.
   / Trying to remove 50 inch oak tree stump with Bobcat backhoe. Struggling #9
Since the ground is very rocky it seems unlikely that you'll end up with a hole as the stump decays, so this advice to cut below the surface and bury seems to be the easiest and best way forward.
Rob
I ordered potassium nitrate off of Amazon last night. From what I read, I can fill the cracks with that then add hot water to dissolve and soak into the wood. Then light it up. I like the idea of adding the charcoal as well. I really don't want to cut it. There are areas where rock is in it and areas without rock. It is a mess. I read that oak roots are 18 inches below surface. It does seem like they go deeper than that though. I think the issue here is that they weave in and out of the ledge.
Any experience with the Potassium Nitrate?
2024 New Holland Skid Steer (A52377)
2024 New Holland...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
Jumper Cables (A53316)
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
Ford 655C 2WD Cab Backhoe (A55301)
Ford 655C 2WD Cab...
