CK3510 idle speed?
/ CK3510 idle speed? #1
TOYBARN
Central VA
Kioti CK3510HSE
Posted question in buyers forum and asking here as well. I recently had to take my CK3510HSE in for a repair. Upon receiving it back 4 weeks later it seems the low idle speed is alot higher than I remember. I would appreciate what others observe there rpm is at idle. Thanks
/ CK3510 idle speed? #3
You should check the specifications for your specific tractor but most seem to idle around 1000 rpm.
Used tractor today to spread a quad axle load of stone. Engine rpm at idle is 1,800 rpm with throttle backed off. Owners manual doesn't specify what rpm speed low idle should be at. Add to the list things that were messed up after having tractor repaired at kioti dealership for 2 hydro oil leaks.
/ CK3510 idle speed? #5
If I'm using the factory manual correctly, it states your engine is a 3F-TM4-U/3F-TH4-U (manual trans/HST trans) and on page 3-9 says 'Maximum/Minimum Speed 2750/850 RPM. For the 3A-165 CK2610 it states it a bit differently as 2600/1150 (+/- 50) RPM. Hopefully it is something simple. Toukow
