Radial tires vs rocks
/ Radial tires vs rocks #1
oosik
Epic Contributor
AMBER, WA
2009 Kubota M6040
I'm considering radial tires for my Kubota M6040. I have sharp basaltic lava bedrock outcroppings and lava rocks on my property. I avoid the outcroppings like the plague. However - slowly but surely the single rocks DO take bites out of the tire chevrons. After twelve years my bias ply rear tires look like they were the main feature at a corn eating festival.
For those of you "in the know". Would radials be any less prone to this situation. I ask because the conversion is a LARGE cost.
Thanks for your input.
/ Radial tires vs rocks #2
I believe the radials would not fare better, after all they are still rubber.
Save your $$'s towards the next change.(in another 12 years)
/ Radial tires vs rocks #3
Go for the same bias ply replacement tires!
In 12 more years you will be 91. I'll be 92, and both of us may be riding tricycles instead of tractors.
I believe the radials might actually be more susceptible to damage in your situation.
Thanks guys. I wondered about that. Besides - the change over from bias to radial is so darn expensive. Bias is plenty expensive as it is.
Ahhh - the current tires are, in all reality, still OK. The rears have chunks - size of nickels cut out of some of the chevrons.
Attack of the RUBBER beavers.
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
2007 Ford Fusion Sedan (A64557)
2007 Ford Fusion...
Hydraulic Breaker Mini Skid Steer Attachment (A64553)
Hydraulic Breaker...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
