Interesting modification
/ Interesting modification #1
joecoin
Gold Member
Milan, OH
Steiner 420 / Grillo 107d
I saw this "dump truck" listed for sale on a social media sight. Looks like it might be a BCS tractor?
/ Interesting modification #2
Quite common in Europe.
Dealers will take a 2 wheel drive tractor like a BCS, Pasquali, and others. Attach it to a trailer, usually fitted with a differential and a 4/5 speed gearbox. The tractor will then power the gearbox through the PTO and transfer power to the differential where the weight will be once the trailer is loaded.
Most of them won't dump. Unless the owners do the modification on the trailer to dump.
My dad had one a looong time ago. It would go uphill with the trailer fully loaded of logs. Nothing would stop that little tractor. It had a 18HP Diesel engine.
Some random pictures from the internet:
/ Interesting modification #3
Thats what they use overseas for everything.
/ Interesting modification #4
That is most likely an Chinese YB-22L diesel 2 wheel tractor, or maybe even an original Japanese one, can't tell Asia is full of them.
Though this one is missing the handle bars, and has been modified to use a steering wheel and a trailer.
The listing said it had a 6 speed transmission.
/ Interesting modification #7
I have a Goldoni like that. On mine, you take the handlebars off, the trailer has its own steering wheel, throttle, clutch pedal, and a stick attaches to control the gearbox. After a year, I went back to Italy to buy another used Goldoni, because swapping the handlebars and trailer takes about an hour. It is my "pickup truck". My oldest son has been able to drive it since age six.
Someday, I'm going to mount a hydraulic pump to the pulley on the front of the motor, and a cylinder to lift the bed. Manually lifting it with a ton of dirt to dump isn't much fun (unless the load is carefully placed to be well balanced. Even then, there are times I beed to drive forward to dump, and the bad wants to slam back down when empty)Image.jpeg
/ Interesting modification #8
Someday, I'm going to mount a hydraulic pump to the pulley on the front of the motor, and a cylinder to lift the bed. Manually lifting it with a ton of dirt to dump isn't much fun (unless the load is carefully placed to be well balanced. Even then, there are times I need to drive forward to dump, and the bed wants to slam back down when empty)
Thanks Andrew, very interesting setup.
Get on that hydraulic lift system soon :thumbsup:
/ Interesting modification #9
Watching some of the Viet Nam vids, the larger of the breed are using 4 cyl diesels and air brakes on the heavy duty trailers.
/ Interesting modification #10
How could we make one of those? It seems like it's probably easy if you know how, but I wouldn't have any idea where to start. It sure would be useful.
2020 Bobcat E42 R2 Series (A60462)
2020 Bobcat E42 R2...
2005 Big Tex 14TL (A60462)
2005 Big Tex 14TL...
Giyi 44" Excavator Rake w/ Shank (A60463)
Giyi 44" Excavator...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A60736)
2014 FORREST RIVER...
