CK3510HST- is the pin sleeve on one threaded end of your OEM top link longer than the other?
   / CK3510HST- is the pin sleeve on one threaded end of your OEM top link longer than the other? #1
mtsman2
Potter County PA - AKA God's Country PA
Kioti CK3510, Yanmar F22D, JD 2305
Long story short, you miss checking some small things when purchasing a new unit. My OEM top link that came standard with my 3510HST, I noticed that the pin sleeve going through each threaded ends are different. One pin sleeve is longer than the other, see photos. May be hard to see but first photos shows the tractor threaded end pin sleeve is about 1.5" long and the second photos shows the implement end pin sleeve is about 2.5" long. The longer pin sleeve on the implement end makes it difficult to attach some of my existing smaller implements since the sleeve wont fit in-between the bars of the implement.
Is your OEM top link the same? Did they give me a top link from a DK in error?
   / CK3510HST- is the pin sleeve on one threaded end of your OEM top link longer than the other? #2
Everyone I've ever had has been that way.
   / CK3510HST- is the pin sleeve on one threaded end of your OEM top link longer than the other? #3
Just my opinion, the tractor side of your top link looks just fine and is properly fitted and installed. The implement side of your top link is different than my CK4010SE. Mine is a simple rotating ball with a Cat1 hole size, awaiting the pin connection, and is a lot easier to connect implements.
I might add, you can always remove that top link, and bring just your top link to your dealer for a swap. If it's a new tractor, they should provide support to make you happy. Or you can purchase a universal Cat1 top link online or at tractor supply or most farm stores. Try the dealer first, because its certainly possible they used a top link from another tractor.
Interesting that your 4010SE top link does not have a sleeve at all, just the rotating ball.
Yes, I did talk to the dealer and they thought both sleeves should be the same length so I believe they would swap it out for me.
Good info TY Rad. (y)
   / CK3510HST- is the pin sleeve on one threaded end of your OEM top link longer than the other? #5
My Kioti OEM top link did not come with a sleeve. I am thinking, your sleeve reduces yours to the Cat1 pin size, which means your top link was originally a Cat2 size, and when sleeved reduces to Cat1. I have never used a sleeve on the implement side, and see not alot of benefits from the sleeve. That sleeve is a complicating factor.
   / CK3510HST- is the pin sleeve on one threaded end of your OEM top link longer than the other? #6
Is the sleeve removable? Looks like it could be pushed out with perhaps a press or vise using a deep socket. I have not seen the implement side with a sleeve on any of my tractors unless I added it.
   / CK3510HST- is the pin sleeve on one threaded end of your OEM top link longer than the other? #7
Both ends on the toplink on my CK3510SE look like the tractor side on yours. A little bit of a sleeve on either side of the ball.
ok. I am glad you could see the difference in the photos. I suspect I was given an incorrect top link, go figure.
TY Stan
sleeve is not removable, its welded inside the ball of the thread end. Good idea and wish it could be pushed out via a deep socket.
You cant see the sleeve welds in the photos, my error for not initially describing it as welded.
   / CK3510HST- is the pin sleeve on one threaded end of your OEM top link longer than the other? #10
Stan and Mtsman2, I reserved the next CK3510SE that comes in at my closest Kioti dealer. Will be my first Kioti after having 4 Kubota's. I have plans to replace the top link with a hydraulic cylinder as well as the side link (tilt). I will try out the hydraulic cylinders called Magister.
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52128)
2017 Ram 5500...
New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
New Holland...
