New Holland 1630 air intake hose
   / New Holland 1630 air intake hose #1
tlj87
Gold Member
PA
JD 4700, Kubota BX2370-1, Kubota RTV1140CPX, Kubota F3060, Club Car Precedent
Current hose is shot - has a hole and is dry rotted from a period of time when the machine sat for a few years unused by the previous owner.
A new hose is $180! NH part number 86519859.
Any suggestions on how to fabricate my own or other alternatives?
   / New Holland 1630 air intake hose #2
what is the SBA# for the part. On my radiator hose I took the old one with me to a store that I knew the folks there. They told me I can go back and see if I can match up what I had. I was able to find with slight difference but operationally worked exactly as oem. I will try to match it up if possible.
   / New Holland 1630 air intake hose #3
   / New Holland 1630 air intake hose #4
I looked at the air cleaner assembly, cold not see if the flat part of the hose is attached to anything? is that right? if so , a round section might work the same.is there going to be a interference between the hood and the nearly oval part of he air intake hose? I think that shape can be fabbed up using a thin aluminum sheet and rivets. I would open up the old intake and make a template off of that and then transfer that to a piece of sheet metal/aluminum and pop rivet it where I need. Can you post a pictures that shows both end of the hose on the tractor?
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55314)
2025 Mahindra 6075...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2018 John Deere 8320RT Track Tractor (A53485)
2018 John Deere...
2024 Bintelli ActivEV Pulse Electric Cart (A55853)
2024 Bintelli...
