E series more HP with same engine
/ E series more HP with same engine #1
Lineman North Florida
Elite Member
LaCrosse Florida
Farmtrac 360 DTC with FEL & John Deere 5093E with FEL ,Kubota SVL 75-2
I have a 5093E 2011 model tractor and was looking at the specs on the tractor data and realized the 5083, 5093 and the 5101 all have the same engine with different PTO HP output , there is about 12 more HP when you go from the 5083 to the 5093 and about 5 more HP when you go from the 5093 to the 5101 all with the same JD 276 cubic inch power tech engine. My question is how is it done? Larger turbo? Or some other way, just curious.
/ E series more HP with same engine #2
I would guess more fuel with the injector pump ?
My 5101E which I absolutely love : is way stronger & sounds totally different thru the exhaust than my 5093E.
I sold my 5085E & replaced it with a 5115M for the 32spd + 16 additional speeds in creep ranges & the Extra POWER.
I run all 4 R4 tires 90% fluid filled on all of my tractors for traction & stability on my steep hills & banks.
The added weight really hurt the little 85hp Compared to the 93/101hp
/ E series more HP with same engine #3
What size R4 tires are you running?
/ E series more HP with same engine #4
I don't know your particular tractor but a change in timing can have a great effect on horsepower output. If you have a computer controlled engine the computer can be programmed to make these changes and the operator will never know the difference. It can also control the amount of fuel flowing. Of course, like a gasoline engine, valve size can make a difference as well. Some of the engines may have slightly increased compression while keeping the same displacement. Personally I believe a lower powered engine of the same displacement will probably have greater longevity but it's only a theory.
/ E series more HP with same engine #5
A local farmer I know just boosted his 300HP JD to almost 500 HP through a $2500 pirate programing.It can be done.Way cheaper than trading tractors.
/ E series more HP with same engine #6
These pre emissions JD E series aren’t computer controlled. Thank goodness :LOL:
/ E series more HP with same engine #7
12.5/80-18 Fronts 28gals in each
19.5-24 Rears 80gals in each
+ 300lb weights in each rear wheel.
Would you mind when you get a chance posting a picture of the wheel weights, I have my rear tires loaded but I am definately interested in some more weight.
/ E series more HP with same engine #9
I wouldn't mind weights either. I can fill my 85" bucket as full as I can get it and it starts making the rear end light. I'm thinking of buying a Landplane type grader but a much heavier version in a 10' wide model. I think this would solve the ballast issues but weights would suffice. My biggest problem is my tractor is already so darn heavy.
/ E series more HP with same engine #10
The inside weights are 150lbs each on 5093E.
I ran 2 stacked together on the 5085E I sold.
Only one would fit inside the 5115M
The outside weights on 5101E are 350lbs each but I had to turn wheel centers around to accept them & run 4” steel wheel spacers to keep my same width.
/ E series more HP with same engine #11
I looked at the smaller 5045E 5055E 5065E 5075E and the only difference I could find out was the pump settting, 3 cyl turbo with mechanical pump. Considerable price difference between a 5045E and 5075E.
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
2019 KENWORTH T370 FLATBED TRUCK (A65643)
2019 KENWORTH T370...
2019 CENTEX TRAILER 16' COOL DOWN TRAILER (A65643)
2019 CENTEX...
2009 Ford F250 (A66408)
2009 Ford F250...
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
2019 FORD F-350 SUPER DUTY (A65643)
2019 FORD F-350...
