How loud is loud, for a 2006 L48
   / How loud is loud, for a 2006 L48 #1
pmmully
Brevard County, FL
2006 Kubota L48 TLB
I put a new muffler on the old L48, still loud as hell. Looking for exhaust manifold leaks/holes/gasket. Am I chasing a ghost and this vintage was just loud? I heard a newer one, holy crow, quiet.
   / How loud is loud, for a 2006 L48 #2
Mine (2002) makes a normal low sound - simlar to other Kubotas, bigger and smaller. Maybe there's a chunk out of the manifold or gasket where it's hard to see? Is the new muffler OE style?
Not sure what style it is, I just ordered it from a local Kubota dealer.
   / How loud is loud, for a 2006 L48 #4
My guess would be that you have an exhaust leak somewhere.
I have the same vintage (2006) L48 TLB, but mine has only 253 hours, and the original muffler.
I consider mine to be relatively quiet.
   / How loud is loud, for a 2006 L48 #6
Is there room for you to jury-rig an additional muffler onto it, maybe downstream?
The new one you heard, did it have a DPF on it?
Last new L48 was built in 2009......without DPF.
There is no location for adding a second muffler to an L48.
The OP needs to locate the exhaust leak/noise!
   / How loud is loud, for a 2006 L48 #7
I've been on this forum pretty much constantly since buying our Kubota M59 TLB about 12 years ago. Lots of Kubotas in the 45 to 60 hp range use that same basic engine. In fact, your L48 and our M59 both have the same engine except the M59 has an exhaust turbo to boost the HP.
As far as I know, they all sound about the same. At least I don't recall anyone saying that theirs had an exceptionally loud exhaust note. Could it be an exhaust leak? On most diesels an exhaust leak is pretty easy to spot by the smoke stains.
Dealer I bought it from supposedly put a gasket on the exhaust manifold. I just do not know what exactly is "normal". I can tell you some of the new stuff I hear is really quiet for what they are. My ex-ASV was not that quiet when at operating speed.
I just do not know what exactly is "normal" for the vintage. I have to believe in 15 years, things got quieter to some degree. My 2012 dodge 6.7 Cummins is significantly quieter than 2004, and the new 2021 are way quieter than my 2012.
In boats, the big aspect of quietness is the injector pump. My 5.9 12 Valve is loud, but the newer electronic QSB series is so much quieter its not even funny.
Are the new L47's electronic injection? I would assume so to hit emission tiers. My L48 appears to be mechanical.
   / How loud is loud, for a 2006 L48 #9
I have the EXACT same year and model.
I had to remove my muffler to get the (muffler) drain plug out for cleaning.
Obviously, I replaced the muffler gasket for reassembly.
The original gasket (251 hours) was good, and exhaust noise was "normal".
Same "normal" with new gasket!
If your dealer replaced the gasket before you bought your machine, the bolts should still be easy to remove, so you could try just replacing the $8 gasket.
   / How loud is loud, for a 2006 L48 #10
I have a 1996 5.9l Cummins in the truck. Most of diesel noise comes from 6 cylinder inline fuel pump. Don’t like the noise but love the reliability and low maintenance cost.
Adding Stanadyne fuel treatment helps keep it quieter. Also add to the the Kubotas.
Some mufflers get quieter when the get a layer of carbon inside.
Small manifold exhaust leak makes big noise.
2014 Chevrolet Express Cargo Van (A50323)
2014 Chevrolet...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2021 CATERPILLAR 279D3 SKID STEER (A51242)
2021 CATERPILLAR...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
2015 CATERPILLAR 299D SKID STEER (A51242)
2015 CATERPILLAR...
2020 CF Moto 500 Trail (A50514)
2020 CF Moto 500...
