Good morning!!!!
   / Good morning!!!! #131,601
Sitting here enjoying a left over late lunch burrito and a dill pickle. Not a Clausen, though. Apparently there's a glass shortage, and their distribution is taking a hit because they can't source enough jars. There were none at either of the two grocery stores I tried yesterday, so I ended up with a jar of a locally produced spears that are OK, but not as good. They came in a plastic tub...
   / Good morning!!!! #131,602
because the spitting rain never stopped, my brother's car stayed in the garage and I went there instead. It sounded very nice and I tried to make a video of it but
pretty much screwed it up. Solid lifters and those pipes made for quite the racket in the garage.
Car looked so much better with blackwalls on it. Goodyear Assurance, hardly high performance but at least they fit, relatively tiny 205/75/15 tires.
Really isn't any more clearance under the fenders for bigger tires without making suspension changes he doesn't want to do.
Brother did say car rode way better now with radial tires.
   / Good morning!!!! #131,603
check; how about the redish brown walls and to satisfy your wife canary yellow trim? Happy wife, happy life.
Update on DIL, doctor says they will NOT be giving her any more blood transfusions and that she has about two weeks left. Her iron count is down again. Life sucks, then you die.
   / Good morning!!!! #131,604
garlic dill gherkins are my favorites. I buy them when they go on sale which unfortunately is not often. 5 bucks for a jar of pickles and it turns out there are maybe seven in the jar.
Peter Piper knew a profitable business long ago...
   / Good morning!!!! #131,605
Godspeed to you both.
   / Good morning!!!! #131,606
I would expect that you got a rain check,
Those were about the worst handling most obnoxious tire shredding Corvettes ever built,
but oh so much fun to crowd them hard and run the gears.
Over steer on demand from the go pedal.
   / Good morning!!!! #131,607
I like this as well Actually most pickles. Unfortunately my favorites are no longer available. My grandmother made something we called mustard pickles, cucumbers from her garden. Anytime I was lucky enough to be told to geo get a jar from the cellar you could count on them being have gone that meal.lot’s of good memories from those visits.
   / Good morning!!!! #131,608
Hope you didn't get your fair share of this nasty storm,and if you did hope you got some good seat time.
Although it snowed most of the day at work (outside Claremont NH), and wifey said it snowed most the day in Bethel, there was no snow on the roads and probably no more then an inch on the lawn when I got home
Drive in this morning kind of sucked, drive home was wet but easy
PTO driveshaft is ready to pick up, but since I got some hot sandwiches on the way home, I'll pick up the drive shaft and mirrors (for the 4052) tomorrow. Going to be a wet day anyway, so no outside work, I'll wager
   / Good morning!!!! #131,610
Interstate closed because of accident in am drive, fortunately I was at an exit when I saw backup and went right around.
Normal busy work day.
Wife went to her moms, I grilled burgers for supper.
Need gas so I can mow tomorrow. Probably get that in the morning.
Chilly out says 53° but cold wind.
Prays for all.
1629 (A57192)
1629 (A57192)
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
Predator 2000 Inverter/Generator (A57454)
Predator 2000...
3in Poly Pipe- SOLD AS ONE LOT (A59213)
3in Poly Pipe-...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
