Mowing in reverse with SCUT and MMM
   / Mowing in reverse with SCUT and MMM #1
cperky
Gold Member
Middle TN
John Deere 1025r with 120r front end loader, Hustler zero turn mower
While at the JD dealer yesterday I was told that the mid mount mower pto would stop if I go in reverse (1025R) . There is a button to override this. I was also told it was required to have this function by law and that all SCUT would stop the pto. It was stated as a safety feature.
Questions:
1 Does kubota mmm pto stop if you go in reverse (bx2680)?
2. Does this become a nuisance while mowing, do you have to push the button every time you back up then start forward?
3. after backing up ( to turn around etc) do you have to throttle down to re-engage pto before going forward?
   / Mowing in reverse with SCUT and MMM #2
Mine doesn't do that.
Both riding mowers do, but the Craftsman has a factory override.
   / Mowing in reverse with SCUT and MMM #3
Not sure why that would be. The Massey GC series will power the mid-mount PTO in forward and reverse motion AND both the mid-mount and rear PTO are capable of being engaged at the same time. The PTO only rotates one way right?
   / Mowing in reverse with SCUT and MMM #4
Funny part of this my JD riding mower cuts better in reverse than forward........Previous owner actually by passed override so it is full time active.... 12 years now and not a issue... Don't see why it would be a problem with ANY mower if operator is knowledgeable of machine...
   / Mowing in reverse with SCUT and MMM #5
BX2370, MMM only shuts down if butt leaves the seat.
   / Mowing in reverse with SCUT and MMM #6
Questions:
Answers:
1. I don't know about your particular model, but in general, new lawnmowers are now required by law to shutdown in reverse.
2. Yes it is a nuisance but it soon becomes a habit.
3. If you forget to use the by-pass switch, you should idle down to reengage the pto. You don't have to, but it will prevent accumulated damage to the system.
While mowing does the button have to be pushed every time you hit the reverse pedal or can you activate the button once and it stays active until you get off the seat?
   / Mowing in reverse with SCUT and MMM #9
You have to push the button everytime, before you go into reverse.
   / Mowing in reverse with SCUT and MMM #10
I have a JD 2025r, similar to a JD 1025r, and yes bigtiller is correct, you have to hit it every time. It Is the same button you use to turn the pto on, it’s a rocker switch. The mower keeps working but if you forget to hit the switch the tractor will eventually die. The Kubota BX I had did not require this but that 14 years ago, I don’t know about the new Kubota. There is a way to bypass this with some wiring.
I really like my JD2025r but hate this feature. I forget sometimes but usually remember before I kill the tractor. I’m not sure how having to look forward at the dash to hit a button makes it safer, you should be looking backwards. On the larger 2 series, like a 2032r you can disable the function by pressing the buttons on the LCD display, the smaller tractors don’t have these buttons.
   / Mowing in reverse with SCUT and MMM #11
Stupid feature. I had a JD lawn tractor before I got my current machine. On that one the engine would die if you tried to go in reverse without hitting the button. I never disabled it, kept wanting to and never did. I got used to it, so used to it I was mashing my thumb into the dash of my new tractor for the first 2 months I owned it every time I wanted to go in reverse.
I think that constantly turning off the mid pto and back on would be bad for mower. I'm supposed to throttle down to engage/disengage mine to reduce shock stress on the implement.
   / Mowing in reverse with SCUT and MMM #12
As I said above, the Craftsman has a manual override. Turn the ignition/key switch to a second position, then push a button. A red LED comes on and it stays in override until you shut the engine off. Similar to this one:
   / Mowing in reverse with SCUT and MMM #13
Yep,
That picture tells you exactly the type of stupid it's meant to prevent
   / Mowing in reverse with SCUT and MMM #15
Yup, became requirement when people kept cutting toes, feet, legs off their kids. Old people don’t matter. My Kubota GR2120 has a push button - press it to override the reverse cutout. It flashes red after pressing but only needs to be pressed once each time you start the blades and the reverse cutout stays inactive until the next time you start the blades - red light flashing as a warning. Much preferred to my JD which needed the button pressed every reverse.
   / Mowing in reverse with SCUT and MMM #16
Too many stupid grandfathers with their grandchildren riding on fenders caused all of this. Makes a terrible mess.
   / Mowing in reverse with SCUT and MMM #17
I was a fender rider on Grandpas tractor. Though he was always very concerned and careful with me, and explained safety very well.
Thats why I disable safety switched like these. 🤪 :ROFLMAO:
   / Mowing in reverse with SCUT and MMM #18
So this is begging the questions: at what point/size does this not become a required feature? Is it only sub-compacts? only those models frequently sold/marketed with a mid-mount mower? ...and is it only tied to having an implement/load on a mid-PTO? (would seem to become a real nuisance when using a 3pt snowblower)
Just curiosity on my part
   / Mowing in reverse with SCUT and MMM #19
Questions:
The Kubota will allow you to mow in reverse with the MMM. Due to my steep hills and terrain, I mow in reverse ALL-THE-TIME. I mow up, then down my hills in reverse. Yes, having to press a stupid button on the dash while mowing and looking backwards sucked on my previous JD. Nope, the PTO stays running the entire time unless your butt leaves the seat. Mowing with my Kubota is a much better experience than with the JD. IMHO.
Mike
   / Mowing in reverse with SCUT and MMM #20
While safety features can help with safety they're no substitute for teaching/communicating, thinking, and personal responsibility.
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2019 BOBCAT E32I EXCAVATOR (A59823)
2019 BOBCAT E32I...
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
Adams 5T Fertilizer Spreader (A56438)
Adams 5T...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
