Finish for weathered table
   / Finish for weathered table #11
I would treat it just like the wood is done on boats, and use oil. The problem with oil is that you need to do it every year. Sometimes more. There are a lot of oils designed for wood and I'm not sure which to recommend. Some have tints to them, like Sherwin Williams clean oil stains, others are will just protect the wood and make it look nicer like Teak Oil or Danish Oil. But there are quite a few to chose from and sometimes the only way to find what works best for you is trial and error.
   / Finish for weathered table #12
I really like the bright color of the fresh wood, but I wouldn't fight nature on this. I like the weathered look too, and the gray patina it forms helps protect it long term. The wood will breathe, and the Eastern Redcedar is very resistant to decay. I would add some feet to the bare wood, as you can see the algae close to the bottom where it's pulling moisture into the end grain.
   / Finish for weathered table #13
I’d sand it down with an orbital sander and reapply a quality marine spar. Also, get a cover if you don’t already have one.
Mine gets no sun but I cover it anyway.
Thanks guys; I appreciate the advice. I think I will sand it down and see how it looks (good job for my Grandsons). I don't think I want to have to re-do it every year, so I think I'll take the advice and get a high quality boat varnish...I'll ask the Sherwin Williams guys for a recommendation. The table is about 10 years old, and it sits outside, so it's gotten plenty of this Oklahoma weather. It was fun to make.
And yeah, I've been thinking about putting another set of wheels on the rear; it's getting to be a real beast for me to move around. That should stop the mold.
Thanks again,
Dennis
   / Finish for weathered table #15
I’d suggest a marble or granite table top. Maybe even concrete.
If not wipe it down good with alcohol, apply Howard’s Restore a Finish and sand lightly. Apply stain or dye, more alcohol, more Howard’s and say Tung Oil. Polish it and add heat with heat gun. Repeat till your satisfied and then add a layer of paraffin wax. Be prepared to touch it up every year.
Good idea! My wife...Sharn Jean is a seamstress!
I think I'll skip the granite top; it's too heavy now...but the wax is a good idea; I've used Beeswax on some cutting boards in the past.
   / Finish for weathered table #18
Epifanes is what I used on my pool bar. Needs lots of coats, starting with thinned to 50%, then to 30%, then to 20%.
With drying and light sand between coats.
prep is everything, I missed a tiny spot towards the bartender side and it turned grey. Rest of bar looks perfect after being left overwinter with now cover and many feet of snow.
Don't know how well it takes high heat, so would need something to sit between Egg and wood surface?
That's pretty close to the way I finish a gun stock...it really puts a nice finish on wood, but a lot of work.
I installed a piece of granite for the egg to sit on, works great. ou can see it in the first photo. The sides of the egg don't get that hot.
   / Finish for weathered table #20
I am too impatient to do that much sanding. I would probably take it apart, run it through the jointer, seal the whole thing up while it was in pieces, and put it back together.
Alternatively, you could do what people do with decks. Pressure wash, stain, and seal annually. There is no way to permanently finish outdoor wood.
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
2013 Ford Expedition 4x4 SUV (A49461)
2013 Ford...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
