Cheap ways to put a roof over equipment?
   / Cheap ways to put a roof over equipment? #41
Perfect. Doors both ends, and make sure you have lots of ventilation at the roof line. Condensation will rust everything Ferrous.
I plan to vent the containers but just have not gotten around to it. We have had one container for about 6 years and the second container for almost two years and condensation has been a big problem.
   / Cheap ways to put a roof over equipment? #42
Is there any air circulation under the containers? My understanding is that a major source of moisture is from the ground underneath coming up through the floor. Mine has a definite air gap underneath (each corner is supported on ties) and despite very wet winters I've had no condensation.
   / Cheap ways to put a roof over equipment? #43
Yes both containers are 4 to 6 inches off the ground.
   / Cheap ways to put a roof over equipment? #44
The "cheapness" of containers is dependent on location. And unless you spend more $$ they are ugly so getting the lady on board is a must.
A couple of years ago I came really close to getting one but decided to sell off the stuff I did not use very much or at all. I know people with pole barns crammed with junk and add more storage space.
   / Cheap ways to put a roof over equipment? #45
Those fabric covered buildings don't last long, depending on the quality of the fabric. Once the fabric tears, install some metal roofing sheets, easy and durable. I now have 3 sheds covered in this manner and have not had a snow load issue. You MUST get all the hoop frames all level and straight as it really helps the process. One building was a old greenhouse and I built wood ends. Once the metal is screwed to the hoops, it REALLY stiffens up the structure.
It can be even cheaper if you can pick up old roller doors. I use 6 uprights and 3 hoops rolled from 30x30x1.2 SHS.
Works a treat.
No snow here though.
Cheers
   / Cheap ways to put a roof over equipment? #46
No snow here either, so I'm hopeful. I see a few of them around. Depending on how long it lasts you can order new fabric, but if it's not worthwhile I'd cover it with metal also.
   / Cheap ways to put a roof over equipment? #47
They showed up about 6 pm yesterday and installed my shed. Couldn't be happier!
$3400 installed for 18x36 with 13' leg height, and a 3' strip down one side.
   / Cheap ways to put a roof over equipment? #48
I never thought much about roofs until I moved to a place with a roof that needed fixing. Before long, I discovered that roofing is a complicated, expensive, and dangerous job. So when we wanted to replace our roof, I researched how to find the right company for the job. While finding a good roofer, I checked many sites full of reviews, and I opted for carportaustralia.com.au. These guys are the best in our local market, and they have pretty great reviews. Still, I am delighted with the work they do and the materials they use.
   / Cheap ways to put a roof over equipment? #49
Start with some 6x6's and metal roof, then add metal siding when you can afford it.
Heavy Duty Ratchet Load Binders and Chain Set (A53425)
Heavy Duty Ratchet...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
Kubota ZD326 60in Zero Turn Mower (A55851)
Kubota ZD326 60in...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A54814)
2016 Autocar...
2004 Ferrara Apparatus Pumper Fire Truck (A55852)
2004 Ferrara...
