My new Branson
/ My new Branson #1
JM7500
Southern Middle Tennessee
Branson 4820R TLB
Yesterday, I got my new Branson. It's a 4820R with a BL200 loader and BH200 backhoe. I chose it based on the specifications, price and intangibles, like my impression of the quality and dealer.
Thanks to Lance at Midstate Turf and Tractor!
/ My new Branson #2
Congratulations! Just look the part of a teen boy who has to mow the lawn when you walk out of the door past your wife to do “chores”.
And mind the roll over bar, keep it upright when working!
/ My new Branson
The ROPs was down because my shed door is only 7'. I'll ALWAYS operate with the ROPS in place. My shed is just in front of the tractor.
Thanks for the reminder!
/ My new Branson #5
Very nice. Looks like you're ready to get some work done.
/ My new Branson #6
Very nice rig! Congratulations
/ My new Branson #9
A fine piece of equipment. You know, after a week, a plastic surgeon can easily get that ridiculous grin off your face. Enjoy.......
/ My new Branson
I’m going to be grinning a long time. Unfortunately between the weather and a truck that needs work and a full time job, it’s going to be several days before I get to have fun with it.
/ My new Branson #13
Be careful around brush and limbs. Don't turn so tight with power that you push the front tire off the rim. Protect it from rats eating hoses, electrical wires, fuel drain cap (cat, rat poison, naphthalene).
Can you tell I have had my own untoward experiences?
Don't worry about small scratches. It's a tool, not something that goes in a curio cabinet. Do keep it clean. Get comfortable but never complacent. It is a powerful piece of machinery: great for increasing your capacity to accomplish work, but easy to do harm if not respected.
Enjoy and be a good steward of God's earth.
/ My new Branson #15
Nice setup. I always thought about getting a backhoe, but never did. Hope you get as much fun out of yours as I have gotten out of mine.
/ My new Branson #17
I had to slow down my BHs boom with adjustable restrictors. It was jerking the whole tractor around. Could just be my unit's valves or my inexperience or both.
/ My new Branson #18
I've had this too - it's quite twitchy.
I'm not experienced messing with hydraulics - can you describe what you put in (links if possible) and where?
When my backhoe's tossing me around I end up using both valves to slow the one down, but that's not always appropriate to the work being done and I shouldn't need to...
/ My new Branson #19
A couple of these: 1/4 NPT 5 GPM Prince WFC-400 In-Line Flow Control | Flow Control Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
between the hoses and the cylinder. The hose/cylinder fittings are JIC so if you put the right JIC fittings on it plugs right in. I'll look for the exact parts list when I get some time later, and post a pic.
Using a one way on each end lets me adjust them separately- gravity is pulling the whole thing down and the rod end takes less fluid per inch of motion so the two ends are not equal. I set the valve to restrict flow out of the cylinder so there won't be cavitation. I can reach them from the operator station. With a little tuning the jerkiness goes away but it's not too slow. For me anyhow.
I have one more to add to the BH's curl circuit. When I curl the bucket it seems to speed up near the end of its travel, then slam into the stop and eject much of the material from the bucket. I can get it to work right some of the time, it's not as bad as the boom was.
I added another flow control to the loader to reduce bucket flop. It restricts flow out of the curl cylinders as the bucket is dumping.
/ My new Branson #20
Here's the parts numbers from surpluscenter:
2 9-7960-4 1/4 NPT 5 GPM PRINCE WFC-400 IN-LINE FLOW CONTROL
2 9-2404-6-4 JIC 6M x 1/4 NPTM CONNECTOR
2 9-6505-6-4 JIC 6F TO 1/4 NPTM SWIVEL
And here's a pic:
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
RoadTec RP190 (A63689)
17601CFL (A61572)
17601CFL (A61572)
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2009 Caterpillar 345D Hydraulic Excavator (A61572)
2009 Caterpillar...
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
