Pipe in concrete slab, rather than rebar?
   / Pipe in concrete slab, rather than rebar? #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
We have some old 1 1/2" heat pipe which is somewhat pitted, so not suitable for anything else which I would use it for such as a flagpole. I've been thinking about using it for reinforcement, and am wondering if losing that much concrete would affect the structure. It will just be in a couple of small outbuildings, so not that much harm done if it doesn't work as planned; and definitely better than a gravel floor.
   / Pipe in concrete slab, rather than rebar? #2
If the concrete is only 4” thick and the pipe is 1.5” diameter, that’s not much concrete above and below. Rebar only 1/2”-5/8“ so lots more concrete above and below. If I had to guess, the concrete will crack where the pipe is.
Thicker concrete would help, but more costly.
You express the same concerns which I have. 4 inches is too thin here anyways, most slabs are 6 or better. That still only leaves 3 1/2 inches of concrete unless I poured thicker as you say. At current prices of 125$/yard for concrete, it's probably cheaper to buy rebar.
   / Pipe in concrete slab, rather than rebar? #4
Looks like 1/2" rebar is averaging $2/ft retail and only about $.70/ft for 5/8" from steel suppliers
   / Pipe in concrete slab, rather than rebar? #7
I would be concerned with the surface of the pipe. Rebar is not smooth like a pipe wall. The pipe may “slip” in the concrete. The ridges in the rebar helps with tension with in the slab.
   / Pipe in concrete slab, rather than rebar? #8
ALWAYS use fibers in your cement. I laid a 4" pad of cement with fibers on beach sand with no gravel base. That was 25 years ago and zero cracks. I did the same without fibers but with a gravel base, rebar, and it's got plenty of cracks. Either stainless steel or fiberglass.
   / Pipe in concrete slab, rather than rebar? #9
Rebar is “deformed” which all those little ridges grab the concrete. Pipe woukd be to smooth and to big, my guess it would weaken the slab not make it stronger.
   / Pipe in concrete slab, rather than rebar? #10
Find another use for the pipe!
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55302)
BOSS MT 660 Fuel...
Adams 6Ton Hydraulic Lime Spreader (A55301)
Adams 6Ton...
2019 Chevrolet Suburban SUV (A55758)
2019 Chevrolet...
1840 (A51248)
1840 (A51248)
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
