Considering Bobcat CT2035 v. CT2040
   / Considering Bobcat CT2035 v. CT2040 #1
rnjcortez
Massey Ferguson 135
Hi everyone.
I'm looking at purchasing a new CUT and would like some info from anyone that has used one. My old tractor a MF 135 is losing power and can't get the jobs done I need it to do anymore, and 2wd has been somewhat of an issue with implements.
First, has anyone owned a newer Bobcat 2035 or 2040? I will be needing to pull a 5' box blade on gravel driveway, and a 6' disc for food plots. The price is right on these machines, just curious if they can handle a 6' disc.
Second, is there really that much of a difference when looking at the HP. the total difference is 4.7hp. Can the 2035 still pull 6' disc?
Lastly, any feedback from owners on these tractors would be helpful. I know its a rebranded Kioti, just curious if Bobcat owners have had good service with their dealers. No kioti around me.
Thanks,
J
   / Considering Bobcat CT2035 v. CT2040 #2
I had a 27 hp Bobcat. It pulled a 5 foot box blade fine. I don't think that you will run out of power before you run out of traction. I think 35 is enough, but nobody ever ever says ' I wish I gotten the LESS powerful tractor".
It's based on availabilty right now. The 2040 not available till July, the 2035 is available now. I've got a friend that will loan me his tractor to get jobs done, but having to ask each time I need one makes me feel like a PITA.
   / Considering Bobcat CT2035 v. CT2040 #4
I just put a deposit on a CT2040 and the dealer told me that either tractor was the same 30-45 day lead time. Demand is pretty high and all their local stock is sold out for both tractors. They are essentially the same exact tractor and engine, I'd image just a different tune on the engine for the hp bump on the 2040s. My thought process was that $500 was minimal to get the added hp even though the pto isn't that much more.
   / Considering Bobcat CT2035 v. CT2040 #5
I moved a lot of packed dirt with a 5' box blade on my 29 hp JD 790, gravel is easier to move. Limiting factor was always weight, not power, I suspect the same applies to the disc. I don't think the extra 5 hp is going to make any difference in this application.
   / Considering Bobcat CT2035 v. CT2040 #6
After writing this I became curious about the torque differences between the (KIOTI) CK1035 and the CK1040. I was surprised to find very little difference, 85 lb/ft vs 87 lb/ft. Here's where I found the data.
   / Considering Bobcat CT2035 v. CT2040 #7
I think the real difference is the PTO horsepower and iirc that's about 3 horsepower with the HST tractors.
I did go with foam filled tires vs. rim guard on mine for maximum rear ballast. I believe it adds roughly 660 pounds total to the rear.
Did you add any remotes or thumb control for a grapple? When I ask the sales guy he can never give me a price, just says he’ll have to look into it. Curious if I add a rear remote and grapple control on the joystick what the out the door price will end up being.
Thanks
   / Considering Bobcat CT2035 v. CT2040 #9
The sales person not having an answer to that question is a bit concerning. I wonder how much they really know about tractors.....
   / Considering Bobcat CT2035 v. CT2040 #10
My other thread on 2035/40 pricing
Take a look at the thread I posted a couple of weeks ago. I showed the starting and finish invoices for my tractor. I added rear remotes and third function for a grapple about $850 each installed.
flooring (A55758)
flooring (A55758)
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2016 WESTERN STAR 4900 SB DAY CAB (A58214)
2016 WESTERN STAR...
UNITED 5' BOX BLADE (A52708)
UNITED 5' BOX...
LOT: Receiver Hitches, 1/2 Ton Sheet Clamp, Pipe Threader (A59076)
LOT: Receiver...
