Considering Bobcat CT2035 v. CT2040
   / Considering Bobcat CT2035 v. CT2040 #1
rnjcortez
Massey Ferguson 135
Hi everyone.
I'm looking at purchasing a new CUT and would like some info from anyone that has used one. My old tractor a MF 135 is losing power and can't get the jobs done I need it to do anymore, and 2wd has been somewhat of an issue with implements.
First, has anyone owned a newer Bobcat 2035 or 2040? I will be needing to pull a 5' box blade on gravel driveway, and a 6' disc for food plots. The price is right on these machines, just curious if they can handle a 6' disc.
Second, is there really that much of a difference when looking at the HP. the total difference is 4.7hp. Can the 2035 still pull 6' disc?
Lastly, any feedback from owners on these tractors would be helpful. I know its a rebranded Kioti, just curious if Bobcat owners have had good service with their dealers. No kioti around me.
Thanks,
J
   / Considering Bobcat CT2035 v. CT2040 #2
I had a 27 hp Bobcat. It pulled a 5 foot box blade fine. I don't think that you will run out of power before you run out of traction. I think 35 is enough, but nobody ever ever says ' I wish I gotten the LESS powerful tractor".
It's based on availabilty right now. The 2040 not available till July, the 2035 is available now. I've got a friend that will loan me his tractor to get jobs done, but having to ask each time I need one makes me feel like a PITA.
   / Considering Bobcat CT2035 v. CT2040 #4
I just put a deposit on a CT2040 and the dealer told me that either tractor was the same 30-45 day lead time. Demand is pretty high and all their local stock is sold out for both tractors. They are essentially the same exact tractor and engine, I'd image just a different tune on the engine for the hp bump on the 2040s. My thought process was that $500 was minimal to get the added hp even though the pto isn't that much more.
   / Considering Bobcat CT2035 v. CT2040 #5
I moved a lot of packed dirt with a 5' box blade on my 29 hp JD 790, gravel is easier to move. Limiting factor was always weight, not power, I suspect the same applies to the disc. I don't think the extra 5 hp is going to make any difference in this application.
   / Considering Bobcat CT2035 v. CT2040 #6
After writing this I became curious about the torque differences between the (KIOTI) CK1035 and the CK1040. I was surprised to find very little difference, 85 lb/ft vs 87 lb/ft. Here's where I found the data.
   / Considering Bobcat CT2035 v. CT2040 #7
I think the real difference is the PTO horsepower and iirc that's about 3 horsepower with the HST tractors.
I did go with foam filled tires vs. rim guard on mine for maximum rear ballast. I believe it adds roughly 660 pounds total to the rear.
Did you add any remotes or thumb control for a grapple? When I ask the sales guy he can never give me a price, just says he’ll have to look into it. Curious if I add a rear remote and grapple control on the joystick what the out the door price will end up being.
Thanks
   / Considering Bobcat CT2035 v. CT2040 #9
The sales person not having an answer to that question is a bit concerning. I wonder how much they really know about tractors.....
   / Considering Bobcat CT2035 v. CT2040 #10
My other thread on 2035/40 pricing
Take a look at the thread I posted a couple of weeks ago. I showed the starting and finish invoices for my tractor. I added rear remotes and third function for a grapple about $850 each installed.
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
500BBL WHEELED...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
Zero Turn Mower (A55853)
Zero Turn Mower...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
