ISO EZEE flow spreader
/ ISO EZEE flow spreader #1
stogel
Kubota L4400
I am in search of an EZEE flow spreader in working order. Please PM me if you have one you would like to sell. Thanks
/ ISO EZEE flow spreader #2
Some, if not all of the wide pull type spreaders tended to rust out in the bottom, especially if fertilizer was left in them. The John Deere spreader we owned had a replaceable bottom plate on each side of center. I'm not sure about the EZEE FLOW.
That's good to know. Thank you! Do you know what model spreader John Deere made?
/ ISO EZEE flow spreader #4
To be sure we're talking about the same type of implement I'll try to drop an image to one similar to the one I used below. I don't know it's model. Make sure you check that there's a bolt on plate on either side of center as I don't know that they were all replacable. It might also be good to check with Deere and make sure the plates are still available and affordable. I only bought one and that was in the 1970s. It also had a lever that could easily be flipped to remove the lift out tine bars that agitated the seed. There was another lever insude the hopper on ours that opened and closed the opening to adjust flow rate. I'd check the bottom for rust at several lever posituons.
Antique Tractors - Yesterday's Tractors : Parts and Online Community has a section called Implement Alley. Someone there might know about the number.
2017 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A66736)
2017 Toyota Tacoma...
2022 CATERPILLAR 349 EXCAVATOR (A65053)
2022 CATERPILLAR...
2014 Kubota SVL90-2 (A64911)
2014 Kubota...
2018 Dodge Charger Sedan (A66738)
2018 Dodge Charger...
2005 LUFKIN 45'X102" FLATBED TRAILER (A67714)
2005 LUFKIN...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
