Hello
/ Hello #1
jacobsirmans
1987 john deere 1050
Hi everyone. I have a john deere 1050 1987 model. I will be needing help with somethings.
/ Hello #3
Welcome to TBN and the forum.
/ Hello
Thanks everyone. Like a asid I have a 1987 jd 1050 with fel without power steering. It was plummed it as listed below.
1.From the pump they cut the little line and sweated some fittings in. From the pump goes to the bottom of what I can guess is a pressure regulator line to the bottom of it.
2. Out of the top of the pressure regulator to a two position selector valve to isolate the fel and the 3 point. One line goes to the fel valve 2 lever the other goes back down to the small pressure line they cut to the rockshaft.
3. The third port on the pressure regulator goes down to the return line from the pump large line. They "teed" into it.
4. And return out of the valve goes to the transmission.
I would like to change out the two lever control valve out to a joystick control valve. Worked on it most of the afternoon. And have gotten no where.
Look on line and found some info on how to use the ports on the rockshaft. Two ports on the front of it under the seat on the right side of the tractor. Said take the lower plug out and apply a 1/4 plug inside and connect the power in the the fel. Remove the top plug and plum in the pby hose and of course the return to the transmission. I did this and only the loader would work the 3point will not work at all.
Any help would be greatly appreciated. Thanks in advance
/ Hello #6
Welcome aboard from East Tennessee.
/ Hello #7
Welcome to TBN! You might want to post your problem in the JD thread.... might get a better response.
/ Hello #10
Welcome to TBN...enjoy.
2014 JLG 10054 SKYTRAK TELEHANDLER (A60736)
2014 JLG 10054...
(2) Firestone 420/80R46 Tires w/ Rims (A60463)
(2) Firestone...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
2002 International 9200i Truck (A61307)
2002 International...
2023 Kubota RTVX1120 (A60463)
2023 Kubota...
2007 FORD EXPEDITION XLT (A62130)
2007 FORD...
