Architect for home renovation/additions
   / Architect for home renovation/additions #11
Some of the (small time) remodelers I knew used to say that when things are really busy, bid the jobs like you don't want them.
my older brother did kinda high end remodeling for rich folks. he did quite well, lives on a big lake outside of Milwaukee.
that was his philosophy, bid it so high that if you do get it, you have to take it.
I'm building right now and a couple times i've asked subs for numbers......in a few cases the bid was double what i already had.
Everyone here is so busy it's a sellers market for sure.
1 example....my septic was quoted at $7300.00 for a 2 tank pump system from the local guy, goodguy! He was so far behind from the rain he couldn't get to me so i went to another guy.....$13,500.00 and get in line.
Not quite double.
I waited and thank goodness, we had about 8 days without rain and the first guy ........ got er done!
Things have changed since last time i did this.
I'm thinking, 2 tanks, lots of extra drain pipe cause 4 bedroom permit and the land barely perked, 200 ft of 2 inch pump line and all the the house plumbing.......
I bet , in my life, I can never fill it. That's my new goal, fill the septic tanks!
   / Architect for home renovation/additions #12
Not insulting architects, but I’ve never known them to design something on the cheap. It’s been a few years ago but I put a price for construction staking for a performing arts center at the local college. The staking was a small part of the project but somehow I became so fascinated with the specs and plans I got sucked in and read quite a bit. I only vaguely knew what I was reading but I knew enough to know this project was going to come in to high and not get built. The finishes, sound system, HVAC, electrical system were all high end. It didn’t get built. Every music professor, dance teacher, theatre professor got to input what they wanted. It killed the project.
So did your budget match what you wanted? Did the architect just go overboard? Why did you feel you needed an architect? What you get with an architect is maybe making a mistake. They also have some structural engineering skills. Having something built that you think is good but isn’t functional Is what they can save you from. For a house remodel a good contractor can maybe give you what you want.
   / Architect for home renovation/additions #13
Our builder fired our architect :ROFLMAO::LOL: And we were fine with that. We were friends with both of them... architect wanted trusses and the builder wanted a main 4"x16"x 23' beam down the middle. Except the load bearing floors were already done and not at the end where the beam was :oops::eek: Only costed us another grand to fix it.
THAT paid for itself because a week before we moved in; Hurricane Fran dropped a 120' (29" DBH) Popular tree and snapped the beam right in half. If we had the trusses, it would have sheared off both additions of 750 sqft.
That was a rude awakening!!! Went from :sleep: to :poop: in my pants...
   / Architect for home renovation/additions #14
This is a common problem with architects. Often discussed in building and architectural forums. I used Chief Architect software to design my house and was on the forum for several years to learn, and ask questions when I needed to. The forum was heavy with architects and home designers plus some DIY types like me. It was a topic that came up frequently. There are many architects (mind you: many - not all) that just have no clue about building and will end up making plans that cannot be built or are too expensive. The problem was described once as "you wouldn't believe the number of architect's plans that are beautiful and sit in a drawer, never to be built, due to the cost and/or complexity to do so." The ones that do better often have a construction background and have "swung a hammer" earlier in life. Many architects are artists that make their art in buildings and are often not very practical. When You find one that gets it, stick with them. I would almost ask any prospect right off the bat "Have you ever built anything yourself? Describe." If they haven't it is a huge strike against them to me. You can find exceptions, but having that practical grounding in actual building is a big deal, IMO.
Plus as others noted, building materials have skyrocketed in the past year, so that sure doesn't help. And many contractors are alos very busy - causing prices to rise.
   / Architect for home renovation/additions #15
...Many architects are artists that make their art in buildings and are often not very practical....
That's a great statement. Neighbors are looking for a bigger house, finally decided to build another addition and is going through the process right now. I do not envy them one bit.
Before the architect, I think the owner needs to sketch out on paper what they would like then think about about it for a while and re-draw it (several times). Don't let the architect drive unless you have no clue what you want (and if that's the case... you need to step back and ponder it for a while... after all, you'll have to live there!) IMO
   / Architect for home renovation/additions #16
Design is an iterative process. Design to a price point is even more iterative.
I designed our house. I took three years of drafting in high school, and from what I can tell, it is not taught any more, which is a shame since I use the skills from those classes all of the time.
The first design phase was on graph paper, each square is 2 or 4 feet, and started drawing, changing things and throwing away ideas. Before we got to doing more detailed plans I had a stack of graph paper almost an inch thick.
We found our builder by visiting a house under construction. The house was a supposedly energy efficient home. Very unique. A kit home but not like one would think. We had decided that we were NOT going to go with this house for various reasons but we decided to go see it anyway. That is where we met our builder. We talked with the guy who supplied the kit for maybe 30 minutes, then spent hours with the builder. As we drove away from the house, the wife and I looked at each other and said, "We found the builder." :LOL: We went to see him the following week for more talks.
The builder and I would go through our latest graph paper sketches, he would provide a guestimate and I would change things. It took quite a bit of time to get to a point where I started to do blue prints. I actually pulled out my old drafting equipment and was doing the design on paper for awhile before I found the latest and greatest version of the CAD program I had used years before.
We had some design cycles around my "blue prints" but not many changes.
Decades before the above happened, I found a guy in a design business who would draw up the prints. I think he priced by the foot or some such. He was not an architect but drawing houses is really not that hard. There are details one needs to know but it is not rocket science.
Right now, with the tight labor market, high demand for housing and amazing prices for lumber, I would expect building a house to be expensive. Now may not be the time to build. It might be better to hold off.
Having said that, when we built out house, concrete was in short supply because China was buying up all of the worlds cement. We had to wait to get an allotment of cement and we were limited to how much we could get. Thankfully, it was enough and the time delay was not too bad.
Later,
Dan
   / Architect for home renovation/additions #17
I also had drafting in high school and a little in college. I also have access to Autocad. I drew up our house floor plan before we remodeled. I even drew up little pieces of furniture and cut them out so you could move them around on paper. That all helps a lot. We have an Island in our kitchen and my wife wanted a bigger one. We went to a kitchen store and they had a similar sized island and when you saw it in person you realized the size. It’s very hard for people to visualize things on paper. An architect is suppose to do that for you so you don’t screw up.
   / Architect for home renovation/additions #18
I've been working for a year planning the new retirement home. Sticker shock was definitely there for me as well a year ago January. The designer, we didn't use an architect, knew what we wanted to spend. But, I could tell his main focus was designing the home we asked for.
After his first round, we increased garage size and main living area, a bit. The quote was much higher from our first builder than I expected. We did learn that all the quotes were for pretty high-end stuff in the home. Which I'm glad, we are slowly knocking a few of those costs down. Plus original quote, to build is just over one year, which means...
Rebid. The cost of wood and goods jumped us another $20k in 12 months. Signed the contract yesterday and moving forward.
We did get one other bid last year, which was less. When I asked why, mostly it was in lumber. instead of using what I'll call true lumber yard, He would purchase and use 11% discounts from Menards and apply to next purchases. All fixtures from Menards, same thing using 11% discounts as much as possible, other peoples discounts as I wasn't sure how that would all time out. He built very nice homes, but seemed weird to me. Most things were all bid at lower cost, with in my opinion only upwards to go as we selected options in more detail.
I'm not sure in the long run how much savings there would actually be. I've already found the suppliers the contractor went to are much better in helping us through the process, versus shopping Menards or the Internet for stuff, which also takes time. There is a cost to better suppliers. Most of what we've done so far in the higher bid is drop some of the costs with fixtures, flooring, stone, and tile, but we have a long way to go.
   / Architect for home renovation/additions #19
I really wasn't trying to just dump on Architects. There are very good ones out there, but you can run into the more artsy types that end up desinging things that are impractical, unbuildable or just too costly. When I designed our house I had help from an Archie. As I mentioned I was on the Chief Architect Forum a lot back then. I managed to connect with an Archie that went to my college, and right about the same time i was there but we didn't know each other then. The Archies were kind of their own separate world in that school. But it was enough of a connection where he ended up doing some work for me helping me refine the design and it was great.
In a matter of a few days of back and forth, he was able to really clean up the look of the exterior - mainly by designing a window pattern that looked good and proportional while still doing what you needed inside the house. He also cleaned up the master suite layout in one shot and improved it a lot. I still made changes from there, but he set me up with a really good base with those 2 items - window layout and master suite. It was a combination of talent and experience. He knew what he was doing and was good at it. He also laid out some ideas that were highly impractical like the use of a Nanawall bank of folding door/windows. They are really neat but would be a disaster in this climate. But I knew enough to say no to those things and yes to the good stuff and we got to a very nice finished design that way. The design is mine, overall, but he really helped improve it for only a couple $k in costs. Well worth it.
   / Architect for home renovation/additions #20
My father was an architect. A very good one. He was also a certified construction specification writer. One of only a few in the entire state at the time. So not only could he do the design plans, he could specify the different materials to be used, how the contractor had to use the materials, and the costs of the materials. Everything from the foundation concrete to the paint on the walls. All of it.
I think you might be hard-pressed to find a residential architect with that kind of knowledge. They have to work with others to develop materials lists and prices, engineering, and so on.
Most people wanting to build a home would be better served to pour through existing house plan books and find something very close to what they want. Then talk to builders about modifying those plans, and skip the architect all together. Pretty much all of the floor plans have already been thought of. Unless you're looking for something completely unique (and are willing to pay through the nose), there's probably a plan out there already that will suite you well.
Remodels and additions are a bit different, however, if you keep the exterior of the addition similar to the existing structure, the builder won't have too much trouble matching it. Interior details are where an architect could be helpful on a remodel/addition, but so could a designer and a builder.
Just remember that in many places, you might need "stamped" documents from an architect or engineer.
PROTEMP 175,000 BTU HEATER (A52708)
PROTEMP 175,000...
2018 Ford F-350 (A55973)
2018 Ford F-350...
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
CLARK FORKLIFT MAST W/ 3PT HITCH (A58374)
CLARK FORKLIFT...
2011 Big Tex 18' Trailer, VIN: 16VCX182XB2E04765, Tandem Axle, GVWR: 7,000 Lbs., Asset# 25 (A59076)
2011 Big Tex 18'...
2000 Mack CH613 MaxiCruise (A57148)
2000 Mack CH613...
