Hydraulic line sleeve/abrasion protection : what do you use?
   / Hydraulic line sleeve/abrasion protection : what do you use? #1
mangler
Gold Member
Ontario, Canada
Sears G5500, Kioti CK2610
I now have a few implements with hydraulic hoses, with some obvious abrasion points. I can reduce most of it with creative tiewrap use, but there will still be some areas that will be more prone to rubbing/wear and tear. What do you use to protect your hoses? Nylon tube sleeve, plastic spiral wrap, velcro sleeves?
I would rather get a solution that allows me to protect the hoses still attached (less mess), but will consider all options.
The loader hoses on my Kioti have a nice nylon velcro sleeve, but it is a bit low on coverage and is already fraying. Ideally I would find another source and overlap the oem sleeve (basically warps all 4 hoses) with another nylon velcro sleeve, increasing coverage and doubling up on the "fraying point".
   / Hydraulic line sleeve/abrasion protection : what do you use? #2
I use the heavy duty plastic spiral wrap you can put it on with out taking the hoses off. It can be a pain in the butt to do sometimes...
   / Hydraulic line sleeve/abrasion protection : what do you use? #3
   / Hydraulic line sleeve/abrasion protection : what do you use? #4
For an area where the three point hydraulic hoses come up over the back -behind the seat - and were exposed to slight wear, I used a foam pipe insulator sleeve. This will do nothing to fix any abrasions but can serve to protect them a bit from getting the abrasions. Where one of those hoses was getting hooked up on the gannon box, when it was raised on a certain angle to engage the scarifiers, I used a bungie core to keep it out of the way- likely I need to rethink why it was getting hooked up in the first place.
   / Hydraulic line sleeve/abrasion protection : what do you use? #6
I used the heavy duty plastic spiral wrap. It IS a PITA to get started. After that it's just a matter of finger strength. It does do a good job and should last forever. I used it on my grapple hoses and my rear blade hoses.
   / Hydraulic line sleeve/abrasion protection : what do you use? #7
   / Hydraulic line sleeve/abrasion protection : what do you use? #8
This looks like a good fit for me, and the price is reasonable too (although I will brace for the standard Canadian upcharge).
Princess Auto sells it in black for $45 for 25' (1" diameter). They also sells the sleeve type for cheaper if you can disconnect the hose.
Are the edges of the spiral rounded? Unclear from the picture. I have seen some that have square edges (looks like someone just spiralled a pipe), they can actually chaffe the hose.
   / Hydraulic line sleeve/abrasion protection : what do you use? #10
The plastic one I posted, does have rounded edges. They also sell it in different sizes and colors...no way it would chaffee anything. It’s easy enough to cut to length, but I would recommend cutting it to length after it’s on.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
71054 (A49346)
71054 (A49346)
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
