PTO Guard/Shield on CK2610 : does it flip up?
   / PTO Guard/Shield on CK2610 : does it flip up? #1
mangler
Gold Member
Ontario, Canada
Sears G5500, Kioti CK2610
I have seen tractors where the shield flips up, and others where it is fixed. Mine seems to be very tight (or fixed...).
Do I need to loosen the bolts, or grease it?
   / PTO Guard/Shield on CK2610 : does it flip up? #2
The shield should 'flip up' with some tension/tightness on the two pivot-bolts so that when you move it up it stays up.
Spray it with some lanolin-based product and, if it still won't move, then loosen it/them a tiny bit.
Looks like the same guy who installs the hydraulic filters at the factory tightened the PTO shield bolts on my tractor... I'll break the bolts loose, retighten and use some teflon dry lube at the pivot points.
   / PTO Guard/Shield on CK2610 : does it flip up? #4
My CK4010 PTO shield flips up. In fact I think all of them flip up in CK line. And mine was definitely overtighten before delivery.
   / PTO Guard/Shield on CK2610 : does it flip up? #5
😄 Ah, yes... the proverbial 800lb. gorilla who also tightens the 'adjustable' end of grease-gun tips.
That 'creature' sure does get around.
   / PTO Guard/Shield on CK2610 : does it flip up? #6
He works for Cummins too! He puts all their oil filters on at the factory😂
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
2013 Dodge Journey SXT SUV (A50324)
2013 Dodge Journey...
2006 KENWORTH T300 SERVICE TRUCK (A51243)
2006 KENWORTH T300...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A52128)
2009 Freightliner...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
Land Honor Skid Steer Pallet Forks (A50515)
Land Honor Skid...
