55 gallon barrel fuel station questions
/ 55 gallon barrel fuel station questions #21
I have found nice compact 12 volt pumps on Chinese web sites in the $10-15 range that work just fine,
They come with a filter screen and about 10 ft of wire c/w an on/off switch.
They fit into a 2.5" bung hole as well as many 5 gal totes.
Since they are an electric 12 volt motor operating directly in the fuel they should NEVER be used for gasoline.
I have been using mine for 2 years now and simply love it.
Pump takes a 5/8 hose for filling and I added a short 1/2" copper pipe and a 90 deg. fitting to hang into my tank filler neck.
It actually pumps so fast that I have to remove the tractor filter screen as it can't handle the flow rate.
You should be able to find by searching Alibaba for 12 volt fuel pump.(and possibly Ebay)
For my fuel line I used 5/8 radiater hose as it is designed for oily greasy environments.
Another nice thing is that it self primes and self drains when U retrieve it from the tank.
Basically it is but a small 12 volt motor driving a multibladed propeller that pushes the fuel up and out.
No pressure is involved but the lift height while not great is adequate for any tractor filling.
My tractor being a CUT and limited tank size means filling up is about a 2 minute chore.
I like it so much that I purchased a second one 'just in case' to have a backup on hand.
/ 55 gallon barrel fuel station questions #22
I started out with a hand pump but with a 100 hp JD and 30 gallon tank that required filling daily, it got old real fast. Match the machine to the task I say.....but now that I have it, everything diesel gets the electric pump.
/ 55 gallon barrel fuel station questions #23
The local fuel company has metal 55 gallon drums with off road. I take old drum in to be filled and take a filled 1 off the pickup with forks on the loader. I would suggest a 3/4 inch T vent so the drum won't be affected by temperature changes as shown in the picture above.
Since Costco is close I don't buy off road anymore just buy 5 gal cans and use a funnel with ridges to vent in the 3/4" bung (make sure you have a vent on the funnel or the other bung open or you'll waste diesel as it spits back at you or on you)
/ 55 gallon barrel fuel station questions #24
Metal drums are not all the same. Some have a coating inside. Others don't. I got a drum that contained Methyl alcohol. I was glad to get it, it was so clean inside. Unfortunately, within 6 months the internals were rusted and contaminated the diesel with rust particles... I then got an used coated oil drum, and have used it for 16 years. The last 4 years, I use the drum as a transfer tank to a 100 gallon tank with an electric pump.
/ 55 gallon barrel fuel station questions #25
Totally sealed works fine if the barrel is full, as even 55gal in a 55gal drum has an inch or so of head space. But be careful about sealing tight a partial filled drum....this is what happens when the weather turns cold ! (I'd imagine it's also quite possible to go the other way if sealed when cold and then the weather turns hot.)
enhance
That's why there is only 45 GL of product in a 55 GL barrel.
Ron
/ 55 gallon barrel fuel station questions #26
I have found that engine oil drums are not as thick as say VP racing fuel drums. Not sure if there coated.
/ 55 gallon barrel fuel station questions #27
I lucked up on some stainless steel drums on craigslist while back.....
enhance
/ 55 gallon barrel fuel station questions #28
In Washington/Oregon we're limited to max of 6 gallon containers both gas and diesel at gas stations unless it's in a transfer tank, However the fuel company had no problem loading the 55gal drum in the pickup./ I now use it a few years then I go and get a new filled drum.
Great idea for the barrel pallet.
/ 55 gallon barrel fuel station questions #29
I use a 55 gallon drum with a 12v Fillrite pump. Usually when the fuel guy comes to fill the heating oil tanks I have him fill up the 55 gallon drum. However I have taken the drum in the back of my truck to the filling station. There's a few thinks you need to think about. 1st 55 gallon drums don't easily tie down in a pick up bed. I made a ring that slides over the top of the drum that has 4 loops in it out of steel. This allows the ratcheting straps to easily work. 2nd if you don't have an easy way to lift it safely then having two drums (if you have a place to store the one not in use) works well. You simply use the pump to transfer the fuel from the tank in the truck to the tank that's not. 3rd you will want the tank either in a handy place or on wheels so it can be rolled around your shop. 4th you will want to put a quick disconnect/ plug both the hose and the power cord on the pump. Since my pump is 12v I didn't want to use the typical 110v plug so I used a twist lock and the prong that's normally the ground I used for +12v and the neutral prong for the -12v. That way if it is plugged into 110v by mistake nothing bad should happen. That way when you screw the pump into the drum you are not fighting the cord and hose. Also with the hose removed when not in use it's less likely to get dry rot damage. I don't have a picture of the ring I made but here's the disconnect and plug.
/ 55 gallon barrel fuel station questions #30
where in ca are you located? If your in the bay area there are places that can deliver.
/ 55 gallon barrel fuel station questions #31
Hi, reviving this thread. I’m a newbie and want to make a 55 gallon drum in to a fuel transfer station. I’ve found both electric and manual pumps that will work with GASOLINE. Yes my application is gasoline not diesel. Further more it’s not regular automotive gas, rather it’s 100LL avgas. It will be stored indoors but will spend some time outside.
My questions are:
1) What’s the best type of drum to get? The stainless ones seem obvious but they’re prohibitively expensive. What’s a good alternative that’s more reasonably priced? I don’t think plastic will support the pump assembly until it’s very heavy gauge plastic.
2) How does one fill it when the pump is installed? Will a smaller gas pump nozzle fit in the smaller hole that’s standard?
3) Do the pumps self vent? Otherwise does the smaller hole need to be opened when pumping?
4) What’s the best way to relieve pressure during temperature changes? Is there some kind of pressure valve that can be installed? I’m not keen on leaving it open for obvious reasons.
5) Any clever ways to check the fuel level? Or just a home made dipstick through the smaller hole?
6) I’m thinking about getting one of the dollys that’s specifically for 55 gallon drums. Does anybody here have experience with those?
7) The cheap Chinese kind you can buy on Amazon for $300 (35 gallon kind) seem ok but the reviews indicated that they have a lot of problems. They’re also manual pumps which makes single user operation more challenging for my application.
Thanks!!!
/ 55 gallon barrel fuel station questions #32
My questions are:
Thanks!!!
1) My gasoline drum (soon to be diesel drum) is steel with some type of painted lining. It has been fine for the past 20 years or so.
I have temporarily used plastic drums for some diesel that I acquired for free, and yes, they don't do so well with the weight of a pump.
2) I fill through the small threaded port with a large funnel
3) I assume the pump does vent while pumping. I have never vented the drum while pumping, and don't notice a vacuum that has any consequence.
4) I do not vent my drum, as it is stored in a shed and not exposed to drastic temperature swings.
5) I have a chart and 1/2" PVC pipe that I stick the drum with.
6) Harbour Freight makes a drum Dollie that I use. I also have a scissor type grabber, but rarely use it.
7) I like to buy reasonable quality tools and gear. I have a GPI manual pump and an auto shutoff nozzle, which have been very reliable and easy enough to use.
/ 55 gallon barrel fuel station questions #33
Biggest thing you should know is unless you're going to have someone deliver or know someone with a truck tank our state laws in WA.(maybe in OR) limit you to 6 gallon containers...So I have to fill 2-3 5 galllon diesel tanks at Costco ( cheapest top- tier fuel in my area) and dump them into my drum, or go to a fuel dealer and he'll sell you a 55gal drum full you can take home with a drum deposit then when you need to you take the empty back and get a new full drum I use forks on FEL to move a drum off of the Pickup Currently I have a 12volt pump mounted on my diesel drum; hooks up to tractor battery to refuel. you can get a hand pump. It depends on how much work you're doing with your equipment. I do about 100hrs per year so a 55 gal drum lasts 8-9 months. Av gas is way more flammable then diesel!
/ 55 gallon barrel fuel station questions #34
I have found that VP racing(old fuel drums) where alot thicker than old oil drums. I would never use plastic and any one of them need to be vented.
Durring the low home heating oil prices about a year ago I decided it was time to fill my spare 275gal oil tank. It should last about 5yrs. Its treated with anti algee additive.
/ 55 gallon barrel fuel station questions #35
Thank you!!!
Ive found used stainless drums at much more reasonable prices so I’ll likely go that route unless one of my racing buddies can get me a VP drum.
/ 55 gallon barrel fuel station questions #36
I'm not sure how much your paying for a SS drum but if it's a few hundred dollars I would just get a tank for in the back of a truck. I got my barrels for free or $10 and a hand crank Agway pump for $50. If i had to pay serious money i would just get a real tank and pump.
/ 55 gallon barrel fuel station questions #37
If you are going to transport your fuel from a fueling station to your home/farm, it needs to be DOT approved. You sure don't want to spill 50 gallons of diesel somewhere due to a ruptured plastic barrel. You can pick up a 55 gallon transfer tank from Tractor Supply for less than $300. I see them frequently on craigs list for much less.
Not necessarily....read the rules. 3 cans at 50 gallons per, come in under the DOT Plackarding requirement!!!!! I earned the Haz-Mat and Tanker Endorsements to my Class A CDL so I was aware of plackarding requirements back when I had an 18 wheel rock bucket.
/ 55 gallon barrel fuel station questions #38
enhance
There is another way you can do that too......forget to pop the vent plug and start filling your tractor. Depending on the amount of fuel in the tank, you can do that too....Daaaaaaaaa!!!!! But I just did it recently and I have been running my fuel supply this way for probably 30 years. I did manage to get the can straighten back out for the most part.
/ 55 gallon barrel fuel station questions #39
What’s a real tank and pump? All I see are the cheap ones on Amazon, and they look like crap and have manual pumps only. The bigger nicer ones are thousands of dollars.
/ 55 gallon barrel fuel station questions #40
Thanks. I have access to a pump or fuel truck to refill the drum.
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
2012 Ford F-350 4x4 Ext. Cab Rugby HR-520 Mason Dump Truck (A59230)
2012 Ford F-350...
UNUSED RAYTREE RMDM72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
CASE IH MAXXUM 115 TRACTOR (A60430)
CASE IH MAXXUM 115...
2020 STAR 4 SEATER ELECTRIC GOLF CART (A60430)
2020 STAR 4 SEATER...
