GC Series - 23 or 25 HP from the same size engine: How do they do that?
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #1
JerryC999
Member
Simpsonville, KY
Kubota B7100, MF GC1715
From my reading, specs on the engines on the GC MF 23/25 horse tractors are the same. But the higher horse engines run at a couple hundred higher rpm. What all is going on with that? I have a GC1715 (with about 20 hours on it now), so I get that extra couple of horses, but I don't understand how.
And a related question about RPMs: They say breaking the engine in means that you run it full throttle for the first 50 hours. Does that mean all the time? When idling? Just when under load?
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #2
The extra hp on the 25 engine comes from running at a higher rpm - that's it. They set the governor higher to accomplish that.
As far as the full throttle until 50 hours - I still vary it a little. I go through warm up at a lower throttle and bump it up until finally reaching the green zone. I still vary the rpms a little while riding around - just no lugging.
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #3
A lot of tractors in the last 10 to 15 years -- big and small -- use exactly the same engine but with horsepower ratings that vary over quite a surprising range of HP. The timing and duration of injection bursts (plus many things I do not know about) are controlled electronically and the chips or other electronic controls vary to get the different power out of the same mechanical engine. I know this was true on the larger MF 2600 series 10 years ago and is true on other newer 3 cyl. MF engines if you read the specs carefully. It's neither a governor issue nor an rpm issue , it's programming, software and electronics. They may change the rated rpm numbers some but that is not why your horsepower is changing.
And so it all begs the question: If this is simply tweaks to the same engine, why not pick the optimum tweak for durability and function, and stay there? If my 1715 is tweaked to deliver a couple more horsepower, does that come at the cost of longevity?
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #5
On the GC series subcompact from what I can see the difference in HP is RPMs only, as this engine is a mechanical injected DI design no electronics or computer management controls that I can see on my GC1723EB.
I think when they say full throttle they mean when working the tractor, you can idle to warm up or stopping for a moment.
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #6
I'm not sure about these small diesels but when I had my Cummins 12-valve, you could go from 215HP to 1000HP by goosing the fuel and air intake volume. In newer diesels, a computer controlled intake system does the same thing with a "tune.' So diesels can have a power output range within a given displacement based on the fuel and air applied. I agree that in these engines, it is only a governor difference, but it is also only a 2-3 HP increase and at that, what's the point?
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #7
It could be that they have a derated version to defeat some municipality requirements. Remember when Johnson and Evinrude made the 9.9 hp outboards? If I recall that was to get around some state's requirement to license a boat with ten horse or larger engines.
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #8
anyone check fuel injector part numbers between the 23 and 25hp versions?
that little HP easily could be done simply with different injectors.
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #9
Hmmm good question
   / GC Series - 23 or 25 HP from the same size engine: How do they do that? #10
I know the PTO gearing is different too, to make up for the difference in Revs.
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
12in Backhoe Bucket (A52128)
12in Backhoe...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
