plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 4,046
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
My pond spillway is concrete. It has a provision to put boards across the face of it, horizontally, to prevent water from escaping and raise the pond level. The boards currently are 2 x 8's. About 40" from side to side, and I can stack 3 more boards on top of the first.
The 2 x 8's act as a dam when the pond level rises, but it leaks everywhere. From under the "bottom" 2 x 8 where it touches the concrete, along the sides where the 2 x 8 edges touch the concrete, and in-between each 2 x 8 stacked on each other.
A few questions:
1. What would be a good sealing material between the wood barrier and the concrete?
2. A single sheet of plywood could replace several of the bottom boards. Do you think 1 1/8 plywood is strong enough?
3. If I use plywood, how should I paint or treat it before it goes into service?
A few questions:
