LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 12,280
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
My tractors and my heating system have all been using the same fuel all my life.I would point out that oil burning furnaces and boilers had many problems when low sulfur fuels were introduced. These problems initially appeared in Alaska as winter arrived there first during the mandated change in fuel requirements.
The greatly reduced lubricity caused the pump on the oil burner to seize. These pumps had to be re designed
to deal with the new fuel. The new design pumps runs reliably on ultra low sulfur fuels.
Dave M7040
My oil boiler has pumped in excess of 30,000 gallons without being replaced, filters annually and the little screen around the pump a couple of times.
The farm tractors and heating oil tanks are filled from the same truck and the same compartment all the time and have been.
The higher sulfur fuel did have better lubricity and would not have hurt a common rail pump, if it had a dpf that's different.
We started getting bulk diesel fuel in the late 60's prior to that it was just heating oil for the houses, and some of those
with exposed tanks got kerosene.
