Best way to make a 4 season trail through this low spot
   / Best way to make a 4 season trail through this low spot #1
beardley
Cato NY
NH Boomer 30
Looking for some expert advice. My family has about 45 acres, but for 6 months out of the year, I can't take my tractor onto 40 of them because the field has this low area that runs parallel the entire length of it. From about this time, until July I can't get through here with out making a terrible rutty mess. I get a couple dry months, and then its a mess again until there is enough snow to float across.
I'd like to make a single pathway, wide enough for my 30 hp tractor to be able to cleanly get through to the high side of the field. I've had 3 ideas, not sure what's best, or maybe you guys would have some better ideas.
I've thought about a wood bridge, but my concern is its not really high enough, and it will fill in below it, leading to premature rot.
I've thought about a soil bridge with culverts, but I'm afraid of them getting plugged, causing the field to back up.
Lastly, I've thought I could dig down and then refill a trench with rubble gravel, making a firm base, but still at the same plane as the current low spot.
Thoughts?
   / Best way to make a 4 season trail through this low spot #4
5" field tile placed 3' deep and a line every 60'
   / Best way to make a 4 season trail through this low spot #5
You have a front loader on your tractor, yeah?
Dig it into the ground in a suitable location until your bucket is full of soil. Drive to the low area, dump it. Repeat ~100x until your have a raised causeway through the low area.
Just raising it would cause a "dam". It is more or less a runoff stream from the hill in the back of the picture flowing right to left. I don't want to just block it off, as it would likely flood more of the field or my neighbors land.
I did also consider the corduroy road, but I'm concerned about the longevity. Most of what I have is ash or sugar maple.
   / Best way to make a 4 season trail through this low spot #7
Fair enough. You could always make a section of the causeway with a row of metal or plastic culvert pipes underneath it at the current ground level Sure they might plug up eventually, but you can clean them out easily enough, just a bit of manual labor every several years. They shouldn't ever collapse on you, if installed correctly. I agree with your apprehension about making a long wooden bridge - this would be expensive and eventually fail on you.
how far across is the wet spot?
All in, it probably needs to cover about 75'. I think from there some gravel on each end should make things stable enough.
   / Best way to make a 4 season trail through this low spot #9
   / Best way to make a 4 season trail through this low spot #10
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
NEW HOLLAND BR780 HAY BALER (A51243)
NEW HOLLAND BR780...
550 GAL STAINLESS STEEL VAT (A51244)
550 GAL STAINLESS...
Wolverine Quick Attach Brush Grapple (A50515)
Wolverine Quick...
36" Smooth Excavator Bucket (A50774)
36" Smooth...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
