B2601: Removing Front End Loader without the Bucket attached?
   / B2601: Removing Front End Loader without the Bucket attached?
The bucket from the L won't fit on the B?
I’m assuming it will. Both my B2601 and L2501 have the Quick Attach Loader/Bucket. However, I would like the ability to use both Buckets on the L2501. I can’t do that if I have to store the B2601 Loader with a Bucket attached to the loader.
Mike
I doubt it. The OP has a B. I have a BX, but I did forget to mention, I tried the same thing with my B2620.
I believe both Buckets will fit on either tractor. Both have the Quick Attach and I measured them at the dealership and they appear to be the same.
Mike
I’m trying to finagle a deal on a B2601 right now. If I get one, I’ll still be working on this. I will say, the SSQA might give you enough weight to pop the loader out if the stanchions, but without the bucket, you lose the ability to pivot the loader frame on the stand to get the loader back in the stanchions.
Now, you might consider making a 2-piece dolly that allows you to remove the loader with the bucket, then remove the bucket and unbuckle a portion of the dolly to roll away the bucket. I store my bucket on a shelf with my MMM above my bagger, so I need the loader to put it up there.
I’ll be working on this, and I’ll pipe in if I get it figured out... and I WILL.
A two piece dolly makes sense and I could see that working. Although, a setup like that might be a little too complicated for me to fabricate.
Definitely keep us updated if you get this figured out.
Mike
   / B2601: Removing Front End Loader without the Bucket attached? #14
You can buy a SSQA plate on eBay for like $100. Get one and bolt it to a log or something for ballast. Detaching and reattaching the loader without something on the quick attach is going to be close to impossible.
   / B2601: Removing Front End Loader without the Bucket attached? #15
I'm curious to learn if it is possible to remove the Front End Loader without the Bucket attached and if the Loader assembly will remain stable if stored without the Bucket?
The reason I'm considering this, is because I don't plan on storing my B2601 with the Loader attached and I may want to use the smaller Bucket (with BX piranha tooth bar) on my L2501 for some tasks where a smaller Bucket might prove useful.
So, out of curiosity, has anyone successfully removed their Front End Loader without the Bucket attached and what was your experience?
Thanks,
Mike
Many things can be done with enough time and/or effort and this will require some of both because the bucket curl function is used to lift/lower the rear of the FEL frame during removal/installation.
SDT
I'm gonna look into this! Thanks for the suggestion! I've got plenty of logs to use, lol
Mike
   / B2601: Removing Front End Loader without the Bucket attached? #17
I tried this - without the bucket i could not move the loader into position and it was a disaster Lol
   / B2601: Removing Front End Loader without the Bucket attached? #18
B/L SSQA buckets are all but certain to interchange. That's why they call it "universal".
to the OP.
curl your SSQA plate out and position it flat on the ground before you dismount your loader. Throw a cement block on it and dismount the loader.
I’m sorry it wasn’t a favorable outcome but, thanks for posting your experience.
I thinking the best way to go will be buying the SSQA plate from eBay and mounting that plate to an object that will allow the loader to sit properly.
Mike
to the OP.
UNUSED SDLANCH SDLD 25 HYD DUMP BUGGY (A57192)
UNUSED SDLANCH...
UNUSED SDLANCH PORTABLE WOOD CHIPPER (A57193)
UNUSED SDLANCH...
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
UNUSED FUTURE SB05 MINI HYD BREAKER (A57193)
UNUSED FUTURE SB05...
2022 Case IH MD93 (A56469)
2022 Case IH MD93...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
