Insight on buying a mini excavator vs renting
   / Insight on buying a mini excavator vs renting #241
How many trips (disregard the obvious speed difference) do you need to make with a mini-ex to move one yard of excavated material 300 feet?
I would just load it into my dump ruck and make 1 trip...How land would it tale you to dog a 300 foot trench 4 feet deep with your backhoe....
   / Insight on buying a mini excavator vs renting #242
I wonder which half is the operable one? The helo, or the mini? Jon
It doesn’t look like anything close to enough rotor to fly it and the mini would be totally worthless with that much tail swing even if the boom was operational.
   / Insight on buying a mini excavator vs renting #243
You know its a joke right.....
   / Insight on buying a mini excavator vs renting #244
Backhoe was a great tool for me on the construction sites. You can dig about any foundation, unload lumber or pallets, load a dump truck or grade off a new lawn area. I had forks which I liked using for steel beams, long garage door heads, etc.
   / Insight on buying a mini excavator vs renting #245
The point being that a mini is a trench digging one trick pony, the TLB is much more versatile.
Not every person who owns a mini also owns, maintains, licenses, and insures, a dump truck,..... to haul material 300 ft.
   / Insight on buying a mini excavator vs renting #246
I’m not sure what the point of the joke was. You might as well put a fire pit up there and throw money in it.
Checked out the Case again. Older at 15 years but decent shape. Only new paint is on the tail weight. Everything is tight. Brand new bucket and thumb. Hmmm PXL_20210226_183804920.jpgPXL_20210226_183756206.jpgPXL_20210226_183751039.jpgPXL_20210226_183748458.jpgPXL_20210226_183738755.jpgPXL_20210226_183734216.jpg
   / Insight on buying a mini excavator vs renting #248
Not bad looking......
   / Insight on buying a mini excavator vs renting #249
Its funny that's all...
   / Insight on buying a mini excavator vs renting #250
A few things that I use my MiniX for, other than digging a trench.. Is loading and unloading the salt spreader from the back of the dump truck. Can also be done with the BH but the mini is easier and faster. Digging and moving stumps.. Can also be done with the BH but so much faster and easier with the mini. Piling brush onto the burn piles every year... Soooo much faster and easier with the mini. I bought a Rutt rough cut mower last year for the mini x as well.. That thing is really nice to cut back the over growth...waaaaaay faster than doing it by hand.
A mini is certainly not just a trenching machine. They are a utility knife that can do several tasks.
2012 FREIGHTLINER CORONADO 122 (A55745)
2012 FREIGHTLINER...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A55302)
2022 John Deere...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A55787)
2017 Bomag BW90...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A55788)
2012 Peterbilt 337...
2009 PETERBILT 365 (A55745)
2009 PETERBILT 365...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
