Garage hacks, adjustments and annoyances.........
   / Garage hacks, adjustments and annoyances......... #313
And then there's plan C:
   / Garage hacks, adjustments and annoyances......... #315
That thing looks like it doubles as a space helmet...take that bad boy on a space-x cruise! How much is that thing, $10k or sumsuch?
3M Speedglas 91XX SW FX Darkening Welding Helmet w/Adflo, Hornell Speedglass | eBay
This is right now about the best buy for a new Add-Flow welding hood, they're usually around 2k, there is plenty of good used ones on ebay for a lot less. Another high point I like is adjustable welding shades. If I was well off and or if I had a big paying home welding job to do I'd get one, they're about the best welding hood around.
3M 51141561578 Adflo 36-111-2SW PAPR with Speedglass Welding Helmet, 91 FX-Air and 91X ADF, Standard, Black/Purple: Amazon.com: Industrial & Scientific
WeldingSupply 36-111-3SW $1887.5
   / Garage hacks, adjustments and annoyances......... #317
and here I am thinking I'm high rolling with my Vulcan welding helmet... :)
That said, I really do like the Vulcan helmet... it is ridiculously clear compared to the normal cheapie auto darkening helmets. I was suckered in with an open box version for $105 so only 100% more $ than what I went in to get instead of 200%...
   / Garage hacks, adjustments and annoyances......... #318
My Jackson boss helmet has adjustable darkening lens for welding, plus grinding option and gas cutting setting.
   / Garage hacks, adjustments and annoyances......... #319
HY80 high strength steel 1/2"-1" has to be pre-heated to 125 degrees, I cant find degree symbol on my laptop so I used the asterisk symbol.
My apologies for being late in saying THANKS. The steel doesn't have to be preheated very much does it?
On my tablet ° appears when I tap ?123 then ~[< to the left of the bottom row of letters.
   / Garage hacks, adjustments and annoyances......... #320
.........SNIP
I think I'm high rolling and my HF helmet is one grade and a bunch of money below yours. I'd probably swell up and bust if I had a Vulcan.
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
2012 International 4300 Reefer Truck (A56435)
2012 International...
Golf Cart (A55787)
Golf Cart (A55787)
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
