Sweating Antifreeze?
/ Sweating Antifreeze? #1
fishfrank
Member
I notice when my tractor is in the garage there will sometimes be a very small amount of antifreeze on the ground under the engine. It seems to happen when there is a big swing in temperatures outside ie. hot to cold or cold to hot. Is this normal. Coolant level is never noticeably low. Kioti DK40se
/ Sweating Antifreeze? #2
Not normal.
A couple things to look for:
Loose hose clamp
Leaking freeze plug
Cracked block
Weeping water pump
Not normal.
Loose hose clamp
Leaking freeze plug
Cracked block
Weeping water pump
What does a freeze plug look like and where would it be located?
/ Sweating Antifreeze? #4
Item number 6 is a freeze plug, although Kioti calls them “caps”. There are three on each side of the block. They are small metal disks pressed into the block at the water jackets.
/ Sweating Antifreeze? #5
There’s also an overflow hose which goes to a reserve antifreeze bottle. Check that’s there is no leak there.
/ Sweating Antifreeze? #6
It’s also possible that u have a very minor leak at the head gasket.
It appears to be from the very bottom of the water pump. Tiny leak. Can I just keep running it until it goes?
/ Sweating Antifreeze? #8
There's a weep hole in the back of most (if not all) water pumps. When coolant makes it past the internal bearing seal, it comes out that hole. Usually the leak gets progressively worse over time until it fails completely. I ran an old pickup for a couple years before it went from the occassional drip to total failure.
/ Sweating Antifreeze? #9
There's a weep hole in the back of most (if not all) water pumps. When coolant makes it past the internal bearing seal, it comes out that hole. Usually the leak gets progressively worse over time until it fails completely. I ran an old pickup for a couple years before it went from the occasional drip to total failure.
fishfrank, I agree with Stan B. You should be able to run quite a few hours before you need to rebuild or replace the water pump.
/ Sweating Antifreeze? #10
Those leaks drove many mechanics nuts already. Some of them start around the frezzing point and disappear as soon as it gets warmer or colder. Most of them happen around hose clamps.
Since it's the water pump itself, it's a different animal but the temp range can be a factor.
If you're still under warranty, contact your dealer.
/ Sweating Antifreeze? #11
A leaking water pump is a sign of bearings going out. I wouldn't prolong replacing the pump. They can send a fan through the radiator. If you can get to the fan and wobble it about 1/4" at the blade ends, It's bad enough to change NOW. Don't wait until it empties your coolant. :cool:
/ Sweating Antifreeze? #12
I would do it as soon as possible. I mean, if it's more convenient for some reason in a month, that's "probably" OK too, without too many hours being put on.
Pump was squealing in my Kubota Loader, thought it was belts and used some dressing with no change. Pump seized up quite quickly after that. Like a few months of little use. Never a leak though.
/ Sweating Antifreeze? #14
As others have already covered, coolant leaks are best dealt with sooner vs. later.
Just wanted to toss out one other possibility. I'd bought a replacement aftermarket water pump and also a Felpro perimeter gasket for the WP on a truck 3.7L engine. No play in the original pump, and since I liked the OE impeller design better, I just installed the Felpro gasket on the original pump.
Mine was leaking at the bottom of the pump housing face. The original factory gasket had just age-hardened enough to shrink a tiny bit, causing seepage. All good, with just the replacement Felpro face gasket.
Rgds, D.
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
429860 (A61166)
429860 (A61166)
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
WEILER P265 ASPHALT PAVER (A65053)
WEILER P265...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
2016 John Deere 6155R (A64119)
2016 John Deere...
