Insight on buying a mini excavator vs renting
   / Insight on buying a mini excavator vs renting #131
Everything go's up and up.... Its just the way it goes
   / Insight on buying a mini excavator vs renting #132
I would buy a cat before a case..
   / Insight on buying a mini excavator vs renting #134
Post a bunch of pictures so we can tell you everything that is wrong with it and then also tell you to buy it.
Haha, sounds about right. Good idea though, this can turn into a mini-ex buyer's support thread.
Now if I could just find myself a pristine 7-8k lb machine with hydro thumb for $10k.....
   / Insight on buying a mini excavator vs renting #135
Interesting....how come?
Parts.. Case is like IH. My buddy has a older cat loader and a newer IH, Dresser , Dressta whatever you call it now and you can call cat and parts are sitting on the counter for you call the other place and the story starts.....well I dont have that part here I might be able to get it ......
That's good to know. I figured parts for case wouldn't be too aweful.
We shall see what it looks like
   / Insight on buying a mini excavator vs renting #137
Why not both?
   / Insight on buying a mini excavator vs renting #138
Okay, just went and looked at the cat 303.5. it's in better shape than the seller was making it out to be. It does have play in the bucket pin but the rest of the boom is nice and tight along with the spin bearing.
only leak I could find is the cylinder for the thumb which just needs to be repacked under the machine and undercarriage is nice and dry.
Maintenance is questionable, he says it's been maintained but it was also low on hydraulic fluid so I have to question that. It's obviously got a very slow leak from that cylinder and has been leaking for quite some time judging by the grime of it so I have to wonder how well it's been taken care of.
I'll throw some pictures up when I get home. It's got 3,500 hours on it and he says he wants about 25k for it.
That's a serious chunk of change. Makes me a little gunshine wonders if I should just rent
It was dark when I went so this is all I have.
Worries about it. Was low on hydro fluid but the only leak I found was the thumb cylinder.
Owner said it's weak tracking and the dozer blade won't lift the machine (he demonstrated both to me). But the dig functions work perfectly fine with lots of strength.
When I ran the machine shortly after track strength was normal and the dozer blade would lift the machine up at idle.
This concerns me. Is it just the low hydro oil? Swing seals going bad? Stuck valve? Yeah.....
Honestly it's in way better shape then he made it out to be, but I don't want to be buying something that might have big issues. IMG958213.jpgIMG958218.jpgIMG958219.jpgIMG958219.jpg
2004 Jeep Liberty Limited SUV (A54815)
2004 Jeep Liberty...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
Kubota BX2370 Compact Tractor (RIDE AND DRIVE) (A50775)
Kubota BX2370...
Heavy-Duty D-Ring Shackle Set (A53117)
Heavy-Duty D-Ring...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
CFG Industrial MX15RX (A53316)
CFG Industrial...
