Snow blower evolution
/ Snow blower evolution #1
rbargeron
Elite Member
MA
L5450, L48, L3250, L345
Several threads here talk about "snow weapons" people are using now. Many of us of change our snow tools along the way, as experience racks up.
In my case there have been 5 blowers. First was a draw-forward v-plow type - great for a few inches of fluff.
Then came a rear mount backup
For the center piles left behind I added a drag blade
But I still got a stiff neck - so a front-mount beckoned....
My first ERSKINE was almost perfect, but not wide enough so we stretched one 16"
This rig does it all. It can even side-swipe center piles left at obstacles (with practice)
/ Snow blower evolution #2
Nice history lesson. I see there was also some cab evolution.
/ Snow blower evolution #4
I first plowed and back bladed before switching to snowblowing.
Front and rear blades.
Next came a rear blower.
Currently using a front blower which is by far my favorite way to deal with snow. Rear box blade very helpful as well.
Hmm.... front blower with enclosed cab..... looks like maybe a trend, huh?
WOW! Is that a driven front axle on a Jubilee ? That's the coolest thing I've seen in a while - very impressive (not to mention understated) - where does it get power? That's just great!
My first tractor was an 8n (2wd) but I never knew about 4WD conversions. For pulling an orchard sprayer thru wet spots it would have been great to have. Maybe would have side-stepped the whole Kubota hobby....
I just looked at your great thread about your Ford 860 with Sherman-Napco 4WD . Not a simple bolt-on. Take care, Dick B
Hope more peoples see this - its much better reading than politics :thumbsup:
/ Snow blower evolution #6
This has been my snow removal journey.
I have a sidewalk, 300' driveway, 1/2 mile private road, neighbors to help. Typical snowfall 4-8" Some 10-15" Occasional 15-20". Here is what I have used over the years.
  • 2 cycle paddle snowblower - sidewalk light fluffy snow
  • 8hp 2 stage snowblower - sidewalk 6"+ snow
  • ATV w/5' blade - Driveway up to 8"snow
  • 4x4 Plow Truck - Driveway/Private Road - any amount of snow
  • Rear Blade - Driveway/Private Road up to 8" snow
  • Rear facing Snowblower - Driveway/Private Road - 6"+ snow
  • Rear Pull Snowblower - Driveway/Private Road Up to 24" snow
Those bolded are what I still have
  • 2 cycle paddle snowblower - Light and easy
  • 8hp 2 stage snowblower - Didn't get used enough
  • ATV w/5' blade - Quick way to move snow
  • 4x4 Plow Truck - nothing faster but Disintegrated from lack of use
  • Rear Blade - Not great at rolling snow well off to the side
  • Rear facing Snowblower - Removes any amount of snow, but comes with a stiff neck
  • Rear Pull Snowblower - Fast and efficient - why didn't I do this sooner
No one tool is perfect. Your list might look different.
/ Snow blower evolution #7
The last step of the evolution usually involves moving to FL!
/ Snow blower evolution #9
The front axle is chain driven from a sprocket between the trans and rear end. A transfer case is mounted where the original pto shift lever went. Actually was pretty easy to install. Only required a rear split between trans and rear axle housing, and remove original front spindles and install driven front axle. The 860 is like a bull in the China shop snowblowing lol. The Kubota is so much easier to use up close to buildings and vehicles.Screenshot_20201123-232706.jpg
Hi Dave - Years ago I had a rotating-drum type blower, in a walk-behind size - around 7 hp. Tangential discharge is great for throw distance. The Schulte RDX117 rotating drum design is great for BIG scale snow. If winter gets like that here in MA I'm going with BoylermanCT's post ;)
/ Snow blower evolution #12
I'd rather shovel and plow snow till I'm dead , than move to fla.:drink:
/ Snow blower evolution #14
Amen brother. I would rather shovel and plow snow, scrape car windows, sand an icy sidewalk, and repeat all of his 8 hours later, than deal with a 114 degree July day in Arizona. And not just 114 during the day, it cools all the way down to 102 at night. And what about fighting all of those biting and stinging vermin that don't have to survive a minus 20 morning? No thanks, give me a nice tractor (with a heated cab of course) and I will plow snow from November to April.
/ Snow blower evolution #15
Differences make world go around.
I do not like winter - cold and snow. I want to go outside, play some tennis, take a long walk, see the beach or read a book by the pool.
Right now it’s -1 in St. Louis but 70 in Tampa.
A no brainer for me.
Wherever you are, have fun and be safe.
MoKelly
/ Snow blower evolution #16
Hi Dave - Years ago I had a rotating-drum type blower, in a walk-behind size - around 7 hp. Tangential discharge is great for throw distance. The Schulte 117 rotating drum design is great for BIG scale snow. If winter gets like that here in MA I'm going with BoylermanCT's post ;)
AH!!!, I bet it was an 8 horsepower Briggs and Stratton engine with red paint and a Yardman brand snow blower with the Pelican emblem eh??
/ Snow blower evolution #17
Its starting to snow here and its cold and I am very happy that the ground is frozen and
I am hoping for many fewer deer and blood ticks and chiggers and fewer bad bugs in the soil.
/ Snow blower evolution #18
On blowers where the auger chain is exposed and runs in snow: Is this a problem. Do you have to oil the chain after every use? Grease?
/ Snow blower evolution #19
/ Snow blower evolution #20
On blowers where the auger chain is exposed and runs in snow: Is this a problem. Do you have oil the chain after every use? Grease?
Seems like if you oil the chain after every 8 hours of use everything should be fine, also check the adjustment, so far I haven’t had any problems but this is only the first year owning a blower.
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
Red Oak Boards (A65640)
Red Oak Boards...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2013 Ford Taurus Sedan (A64557)
2013 Ford Taurus...
