Low Crawlspace Underfloor Heating?
/ Low Crawlspace Underfloor Heating? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
Is there such a thing?
This house is going on 70 years old. Concrete block walls that I've added insulation to inside and out. Interior floor is wood frame above a low crawlspace. Maybe 12-18" clearance at most between bottom of floor joists and ground. No way to get under any portion. The only venting is four concrete blocks turned sideways on each side of the house, no access to any of it from inside the house. No chance at all of running any kind of piping or tubing for heated liquid.
But I keep wondering about forced air heat under there. On days like this where the is temperature is in the teens and there is a strong wind, the whole floor feels cold, tile, wood and carpeted/rugged areas. Any warm air down there should help, but I don't want to introduce moisture either.
/ Low Crawlspace Underfloor Heating? #2
If I understand, you are talking about using the underfloor area as a plenum and heating the whole thing. It would probably work, but be very expensive. If you heat outside air, moisture shouldn't be a problem. Relative humidity would be much lower when the temperature is raised a little.
When I worked in HVAC, I once added hot water heat to a house with almost no clearance under the floor joists. I had to tunnel under the joists and then crawl between them. The worst job I ever did but it got done. It sounds like you really need to find a way to insulate the floor.
What kind of heat do you have now?
/ Low Crawlspace Underfloor Heating? #3
Is the crawl space under the house dirt? If so, pushing warm air into that area will be futile. So much of it will be cooled by the dirt, or escape through the 4 block vents you mention, that it would take huge amounts of hot air to warm the wood floors, costing you a small fortune.
Can't tunnel. No way under without cutting out a section of block from the outside or floor from the inside. Neither would allow for dirt removal.
Current is a combination of gas forced air, gas radiant (infrared wall mount) and wood stove that I'm looking to eliminate.
Yes, dirt. Vents would have to be blocked in Winter and opened in Summer. Trying to evaluate if it makes sense.
/ Low Crawlspace Underfloor Heating? #5
We've our crawl space sealed off with encapsulation but still have moisture problems. So, we went with a commercial dehumidifier. It warms up the crawl space from its normal 55ish earth temp to mid 60s, which is warmer than we keep the family room on the other side of the wood flooring above it.
Ralph
/ Low Crawlspace Underfloor Heating? #6
Even if you put heated air into that space, the floor will never feel warm to the touch. Think about it. You heat the air until it's 70 in your house, for example. The wood floors, walls, ceiling, furniture, etc... all get to 70ish degrees. Yet you put your feet on them, and they don't feel warm, because they are 70 and your skin is 95ish. That's a 25 degree difference.
The only ways to make your floors feel warm is putting in radiant floor heat, or carpet. Carpet makes a huge difference in how a house feels. But you can't (or at least shouldn't) carpet areas like kitchens and bathrooms.
You could dig out the crawlspace enough to make a workable space to install radiant floor heat under the floors between the joists. That's a big job, but very doable.
/ Low Crawlspace Underfloor Heating? #7
Is Radon an issue in your area? If so, you may not want to have any positive pressure in the crawlspace and push the Radon into the living space.
Another story, but way way back a buddy and I were assigned the task of stapling insulation in a similar space at an old farmhouse. The space was a bit less than a cubit in spots, preventing the use of the staple gun unless the forearm was at an angle.
/ Low Crawlspace Underfloor Heating? #8
I worked with a woman whose husband made a career out of digging out crawl spaces for repairs or installing basements under houses that only had crawl spaces. It's not as hard as it sounds. Just time consuming.
He'd bust out a few blocks and start digging, hauling the dirt out in buckets. When he got a space big enough for his body to fit, he'd insert a conveyor into the hole trough the busted out blocks. Then he'd start scooping the dirt onto the conveyor, which would haul it outside for him and right into his small dump truck. Then it was just a matter of getting a hole deep enough for him to move around comfortably and off he'd go. It helped that he was only about 5' tall. ;)
/ Low Crawlspace Underfloor Heating? #9
Before building a new shop with living quarters above, I considered putting infloor heat into our cottage. It was just like you describe only there was not even 6" of clearance for the majority of the crawlspace. I painstakingly fished pipes and wires to modernize the cottage. One thing I looked into than you may consider is a vacuum truck service. They use these trucks to do delicate work in cities to evaluate around wires, pipes and underground service. They also use them for this type of work and just need a place to dump the wet dirt from the water injected into the suction process.
Something to consider that without a bunch of research and driving through a construction zone in the city did I know was possible.
/ Low Crawlspace Underfloor Heating? #10
Geez. A tough way to make a living, gotta have a lot of respect for a guy like that.
/ Low Crawlspace Underfloor Heating? #11
Yep. He was all hunched over and Gladys said she had to pull him up out of bed each morning and rub down his joints with liniment oil to get him moving. He was a stout man, huge upper body strength, hands like sledge hammers with vice-like grip. Made a good living for him and his family. Three boys. One joined him in the business as I recall. I used to see them in the grocery store holding hands. Well into their 80's, he leaned over against her in church one Sunday, and died immediately. She moved away to live with her daughter and I never saw her again.
/ Low Crawlspace Underfloor Heating? #12
Two years ago I drove by their old house. His old dumptruck and cement mixer were still behind the house.
/ Low Crawlspace Underfloor Heating? #13
Surprised no one wanted the truck...
Did a crawl space digout and worst job ever...
Made it deeper where easier to access and then moved dirt to fill...
Lots of homes here have access through closet floor...
/ Low Crawlspace Underfloor Heating? #14
My wife said no. :laughing:
/ Low Crawlspace Underfloor Heating? #15
I want de mixer. Looks like old Jaeger continuous dat poured lot of city streets back in time some.
Tell wife you just parkin truck for a while cause you hadda use it to haul mixer fer me. She might believe.
Funny and all, but I had considered digging an access path with the BH to get under the wall and ... well, it was a passing thought. Big slope about 15' from the house where the path would have been so dirt disposal would not have been an issue. No idea how I would have shored up the opening and supported the wall. Some kind of steel beam I guess.
/ Low Crawlspace Underfloor Heating? #17
How about electric radiant floor matting installed on top of existing floor.
/ Low Crawlspace Underfloor Heating? #18
Try to contact an electrician company. They will send a specialist who would analyze the situation and give advice.
FIXED FIFTH WHEEL ATTACHMENT (A65643)
FIXED FIFTH WHEEL...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
