Position setting system for garden tractor
/ Position setting system for garden tractor #1
AJMorris
Deutz 7206
Hi
I’m rebuilding a couple of kubota 4-wheel steer garden tractors. One is a g1800 and the other a g1900.
Both have broken chassis and scars from a lifetime of abuse. However all the good bits are functional and a rebuild will have them as per design
New chassis are from 130mm cold rolled channel and are quite a bit more robust than original
As part of the rebuild, I would like to install a position setting hydraulic system for both the cutter deck and the (yet to be built) 3 point linkage.
This would mimic that in big tractors where a lever set to a position and holds that position to keep a constant depth or height as you work.
Is there a ready made sensor/control unit that can be purchased? To best of my knowledge there is nothing original. If there is please let me know. Otherwise aftermarket or adapted systems will
Have to be built.
Just hoping there is some sort of retro fittable “bolt on” solution rather than having to design form scratch
/ Position setting system for garden tractor #2
Skid Steer Flail Mower (A65640)
Skid Steer Flail...
KILLBROS GRAVITY FLOW WAGON (A64277)
KILLBROS GRAVITY...
3Pt Rhino Forklift (A66408)
3Pt Rhino Forklift...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
Steel Wheelbarrow (A65640)
Steel Wheelbarrow...
