New Holland T1520 Power Steering
   / New Holland T1520 Power Steering #1
dragtruck
Proctorville, Oh.
Ford 1715
I just got a 2013 New Holland T1520 tractor and the power steering fluid is low. When I take the filler cap off, I can't see any fluid. The power steering works but it squeals a little when I turn the steering wheel. I don't have an owners manual and there isn't a dip stick to tell when the tank is full. Do I just fill it up to the bottom of the filler cap? Thanks.
   / New Holland T1520 Power Steering #2
Your cap doesn't have a small rubber tube attached to it? The fill level would be about an 1 1/2" from the bottom of the cap.
No, the cap just screws into the top of the pump. It's made of yellow plastic and doesn't have anything attached to it. I have a Ford 1715 that has a cap made like your talking about but the pump and tank are 2 separate pieces on that tractor. The 1520 has a pump and tank all made together.
   / New Holland T1520 Power Steering #4
Disregard what I told you, I thought all of the 20 series had the reservoir.
LEEBOY 400T DOUBLE DRUM ROLLER (A52707)
LEEBOY 400T DOUBLE...
Case 1020 25ft Draper Head (A55315)
Case 1020 25ft...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2023 RTVXG-850 SideKick (A55314)
2023 RTVXG-850...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
24ft T/A Enclosed Cargo Trailer (A53424)
24ft T/A Enclosed...
