Oil & Fuel Checking hydraulic fluid
/ Checking hydraulic fluid #1
radnack
Member
NY
TYM T451
Hi i have a TYM T451 and ive tried checking the hydraulic fluid on it and i cant seem to get a consistent reading on it. Ive parked it in the same spot twice and different readings each time? Ive had it all the from empty to full. Its parked in the most level spot i can find as well. It had a dipstick if that helps. Any idea on which reading i should use or what would be causing this?
/ Checking hydraulic fluid #2
When checking the fluid, make sure you have the loader on the ground and the 3 pt lowered.
If you leave the loader in the air, the dipstick will read empty.
BINGO i put the loader down and it was full! Thank you so much!
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
John Deere MX10 (A64119)
John Deere MX10...
1995 48ft. 38 Ton T/A Flatbed Trailer (A61573)
1995 48ft. 38 Ton...
2025 Safety Basket Forklift Attachment (A61572)
2025 Safety Basket...
GAMOR MACHINE CO. 4R VEGATABLE SEED PLANTER, 3PT (A64280)
GAMOR MACHINE CO...
