Good weld?
/ Good weld? #21
Well I ain't sayin nothin bout no weld made by some fellow who takes picture of de weld after cold, ain't sayin diddle bout lookin at top of weld tryin to tell it good or not either. Don't have no Xray vision kit dat works on screen pictures.
Besides, somebody might cry and Blue Whales poof de post. Got screen shot in case dey do tho.
Now, here picture of factory made attachment made in Peoria by group of Certified UAW fellows usin only finest machinery available. Welder fella was a welding school grad wid paper swore he certified. I think he study cake decorating, very nice piping not damage cake at all. Not stuck but looks pretty.
Welder did his work in jig designed by Engineer fellow and Certified schooled inspector approved de job, looking at cold decoration. Then painter fellow did his magic and shipping guy shipped. Dealer inspected on arrival, no scratched paint.
Sucker who paid high buck for finest equipment on market didn't know it for display and lookin at went and used it. Piping came loose from cake. Good thing nobody under de pick. Sucker took it back to dealer, not covered by Warranty, paint stuck.
Thing like dis shining example why Made in America by first line company means you got screwed.
Thank God painter knew his job and did it.
/ Good weld? #22
Well said, (removed), in glamorous (removed) fashion. :D
Travis
/ Good weld? #24
Being that the weld in question is where most of the force is applied, I would weld it different. It is on the rounded corner of the tubing and it is tough to get deep there. I would be burning some 6010/6011 down there for a root pass.
/ Good weld? #25
Hot and toasty. Even though this is short circuit its well melted from the root out to the toes. Hot enuf that it really doesnt ripple. Pic 1 Hobart 210, pic 2 my 255 red pos, was chasing the spatter. Can see the stop and 1v change to try to get rid of it.
/ Good weld? #26
Looking at the op pic, there's squat for weld on the sq tube on the right hand side. Hurry hurry, time is money. This one slipped by QC. Having seen some pics of their work, that example is not the norm.
/ Good weld? #27
Dem little nubbins you calling spatter is really anchor points for putting nice piping on top. Set hotglue machine to fluff & fill and pile.
Gotta be high and fluffy like Peoria UAW Certified decorator/weldunce.
/ Good weld? #29
sometimes when welding dissimilar thickness metals - like the thick top rail of a fork frame to a thin wall tube, it may seem like you are fusing the metal well, but in reality, if you are too low on the heat it may only be melting in to the thinner metal, and just laying in against the thicker one. I'm not a pro - just a low-brow fab hack so i always try to double check to the best of my ability - I find the easiest telltale signs that i got decent fusion are good heat discoloration on both metals joined, and even a little undercut, while not desirable, will tell you that you are probably burning in ok. Since I'm one of those guys who knows nothing and use to sit behind a desk and punch numbers all day (now i sit behind a desk and tell others to punch numbers all day) I might decide that i only need 7.3829673103 inches of weld, and since you have 4 feet of weld, a few questionable spots probably won't hurt - that's how I operate on my home projects.
as it was so elegantly put, it's hard to tell after you decorate the cake, but i'd probably trust in the quality of a known manufacturer and their quality control catching anything that might be a real concern. That may appall the safety police here, but also remember that safety is not only in the build of the item, but also in its use. most large and smart companies try their best to make sure that nobody is in harms way when an item like this is being used. accidents will always happen, but if you make sure that people are out of the way in the event of a failure, hopefully everyone gets to walk home. nobody wants the cost of material loss, but it's better than losing a person.
/ Good weld? #30
Well, you come from yer experience base, and truth to tell yer thinkin deficiency anemia is probably normal to dat base.
You go look dat picture I posted where da cake decorator went wild wid de hotglue gun, you see where yer idea 1 little defect don't matter fails ta slice de mustard.
Dat assembly of stukta dat looked pretty started unzipping at weakest spot, and once zipper got movin it all come unstuck.
Looks like dat behind de desk experience never had you up close & personal wid a load gone wild either. Best case de falling load stay in one lump before hits ground and after. Forklift rarely best case. Good way to handle material, but generally material held on pallet by gravity alone. Same bunch number guys you hang wid probably got number splains how a buck worth of shrinkwrap or bands not justifiable due to several factors and dat buck better spent in bonuses. From where you guys sit it makes sense. You on de job site yer experience probably not let you see possibility cube of blocks gonna take down scaffold dat gonna hit something else gonna fly and hit Bob just below hardhat as he comes out of blue wart.
On de good side you do recognize heat signature on de weldment is an indicator of deposit quality. Ain't everything, but it a start on education road. Better picture is probably looking at heat picture as weld is being deposited. Best gonna be cut it, polish it and develop it for true story of penetration. One de worst things bout wire welding is deposit of cake piping can look like good weld. Again, look de picture I posted, piping looked real nice, but separation proves piping not even connected to adjacent piping by nothin but stukta.
Again yer viewpoint on first line manufacture is based on where you lookin from. Big yellow in Peoria shipped hundreds of tons of stukta components since 'engineers' lookin at screens had lunch wid bean counters lookin at more screens and decided MIG is best bang fer de buck. Der track record on hydraulic cylinders alone proves engineers don't know much bout welding. Maybe dey engineered cylinders for maximum replacement.
/ Good weld? #31
No, this is a pic from everything attachment. I致e been in the market for a grapple for my track loader. They are very expensive compared to other grapples by 2.5 times. They post pics of welds and I could only imagine theyæ±*e good. But this just looks very uneven to me as you look down the seam.
I find myself just looking at welds on things anymore.
Typical manufacturer squirt gun job. I would not buy that implement. Had one like that on a Kubota attachment, broke first time I used it. No evidence of fusion or penetration on either side. Made them replace.
Ron
/ Good weld? #32
Here is what a Mig weld can do on 3/8-inch thick steel.:cool:
/ Good weld? #33
...and it is so nice to see you back, SA!
/ Good weld? #35
It is very hard to type with one arm! With my on the job brain injury, my right arm does not work! Maybe it will get easier. :thumbsup:
/ Good weld? #37
I'll still stand by my point. every business out there is going to "design" to the need. if the tried and true, proven time after time for decades need is only a 3 on 12 intermittent fillet weld, and someone provides a continuous fillet, then 75% of that weld is excess. if the 3 on 12 need is completely satisfied by a good quality weld, then the rest is mostly irrelevant. if there are a couple sketchy spots in the "bonus areas", it won't do anything detrimental. the key is having a quality weld that satisfies the need. if you don't have a quality weld then it's irrelevant how much you have. if you do have a quality weld, having 4x as much as you need only costs more. if the failure is due to lack of fusion it is irrelevant how it was designed. That's on the guy pulling the trigger, not the guy pushing the keys.
/ Good weld? #38
Good to see you again, Carl. Hope you are able to keep posting!
2020 FREIGHTLINER M2 4X2 S/A 26FT CDL REQUIRED CURTAINSIDE BOX TRUCK (A67148)
2020 FREIGHTLINER...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
Lot of 2 ForeRunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Lot of 2...
2016 CATERPILLAR 303.5E2 CR EXCAVATOR (A65053)
2016 CATERPILLAR...
UNUSED PARBREAK RT140-72" ROOT RAKE (A65055)
UNUSED PARBREAK...
