Advice on converting pin on bucket to SSQA
   / Advice on converting pin on bucket to SSQA #1
CJHL
erie pennsylvania
Kubota B2650, John Deere 5103
Looking for some thoughts/advice on my upcoming project. I have a 60" pin on bucket for my Kubota b2650 that I got to use while I was waiting for my SSQA setup to come in last year when I got the tractor. Due to COVID, The SSQA bracket wasn't available so my dealer delivered the tractor with a 60" pin on for me to use until everything came in. It took like 3 months after initial delivery for everything to be in my hands, but I have it all now. Only dumb thing I did was order the machine with the 54" ssqa bucket instead of the 60" I used the 60" pin on to move roughly 125 yards of topsoil with no issues at all. I kind of felt bad about using the 60 which was new when I got it and giving it back to them in used condition, but it was their suggestion, so I guess they were OK with it. I offered to buy it and figured it would be nice to have both sizes for some reason. $250 seemed like a decent buy for a new/used bucket that was only used by me. Now I didn't realize just how much I would like the whole quick attach setup. I figured on just switching between the 54 and 60 whenever I felt like it. Now I also see that isn't exactly a 30 second job. So this brings me to my question. I have already seen projects where people have cut the pin on mounts off and welded on the adapter plate. I am not questioning that part, what I would like to know is whether or not I should get a full plate or go with one of the cut-out versions. The cut-out ones are about 20 or so pounds lighter than the solid plates, so that would be a plus in my book. I would think the cut-out one is what I would likely go with, but looking for real world experiences from guys that have been down this road before. I just got a 1/4" plate that is a solid piece for my snowplow project that I have to get started on, and it came from palletforks.com Looks like good quality and price was right. They have a 5/16" cutout version that is under $100 and is right around 50# so I am thinking that will probably be the route I will go unless anyone thinks that isn't the best way. Thanks in advance for any thoughts and advice.
   / Advice on converting pin on bucket to SSQA #2
Go with the cut-out version. No need to add unnecessary weight.
   / Advice on converting pin on bucket to SSQA #3
Really not that much of a difference in bucket size to have 2 buckets in my eyes....But if that's what you want go with the cut out plate..And maybe put teeth on one bucket..
   / Advice on converting pin on bucket to SSQA #4
Anti-Wall of Text post.
   / Advice on converting pin on bucket to SSQA #5
Question on the SSQA with the cutout plates: Are there any issues with the tilt cylinders not synchronized?
Edit: Unsynchronized at least until the attachment is installed.
   / Advice on converting pin on bucket to SSQA #6
   / Advice on converting pin on bucket to SSQA #7
My Kubota L2501 has a tube between the two sides so the cylinders stay in sync. I try not to move them any more than absolutely necessary though.
   / Advice on converting pin on bucket to SSQA #8
Is there a concern about twisting the tube? I don't understand as there shouldn't be much load on it just to synchronize the tilt cylinders.
   / Advice on converting pin on bucket to SSQA #9
To be clear it's a welded in tube to keep them in sync. They can get out of sync without it as each one has a different resistance or could have. I converted my L2850 to SSQA and they would get off if you had to move them too far to line up into another attachment.
2013 Ford Taurus (A56859)
2013 Ford Taurus...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
