Wits and Bits of Nothingness, Volume Four
   / Wits and Bits of Nothingness, Volume Four
IMHO, any day that you feel well enough to go cut down a tree is a good day.
   / Wits and Bits of Nothingness, Volume Four #23
It was about eight, but a few of them were under 2" diameter, so I'm not sure they count even though they were about 20' tall. Two were about 4" and one was closer to 6".
   / Wits and Bits of Nothingness, Volume Four #24
I never feel like cutting a tree down. But I sure feel like pulling them up :D
   / Wits and Bits of Nothingness, Volume Four #25
When wearing a ******, a woman reveals 90 % of her body.
Men are so polite they only look at the covered parts...!
   / Wits and Bits of Nothingness, Volume Four #26
   / Wits and Bits of Nothingness, Volume Four #27
Those are really cool pictures. You can pull those trees straight out of the ground with that machine? Amazing strength, shallow roots or both I imagine.
MoKelly
Yep it can pull most straight up. The ones it can't pull, I have to grab higher and push back and forth as it pulls up, to break the roots loose from the clay soil.
Here is the view from the seat of a 4 or 5 inch diameter trunk. Driving up to it:
Clamped on:
Pulled:
Shook the dirt off:
And it is not a big monster huge machine:
   / Wits and Bits of Nothingness, Volume Four #28
Clamped on:
Pulled:
Shook the dirt off:
Thanks!!! Now I want one of those.
MoKelly
   / Wits and Bits of Nothingness, Volume Four #29
MoKelly
Get one, you will be amazed at what it can do!
If the tree is too big for the puller, it gets pushed over, like this dead oak tree four years ago:
Reached in and extended the boom some more:
Found the balance point and took it to the burn pile:
UNUSED FUTURE FT-X39 39" HYD TRENCHER (A57193)
UNUSED FUTURE...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
UNUSED FUTURE DIE-CAST TOY (A57192)
UNUSED FUTURE...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
