Rebuilding property entrance fence and gate; post-mortem on 25+ year old 6x6 PT posts
   / Rebuilding property entrance fence and gate; post-mortem on 25+ year old 6x6 PT posts #1
rbstern
GA
LS MT225E, Yanmar 2210
The fence and gate at the top of our driveway were looking well worn. The setup also had a safety disadvantage: If you pulled into our drive with the gate closed, your vehicle's arse end was still on the roadway. We decided we wanted to demolish the existing fence and rebuild the new setup about 15' further onto the property, for both the aethstetics and improved safety.
The old setup:
A friend just retired from the fence business; he had a set of damaged (a few bent top spikes and vertical rails), aluminum estate-style gates in his warehouse and offered them to me. I was able to straighten the damaged aluminum with considerable pressure using a 5,000lb 4" rachet strap. Not to "as new" quality, but enough that only a close inspection of the gate shows minor creases and deformations in the aluminum where it was bent.
When I demoed the existing fence and gate, I pulled the 6x6 PT gate posts with my FEL. They came up fairly easily, as they were not in concrete. Just a bump to loosen them, and upward with a lifting strap. Other than weathering, they were in remarkable condition for 25+ year old posts. Completely solid, top to bottom. There was a .40 CCA-A tag on one of the posts. A classic case of "they don't make 'em like they used to." I pressure washed them and am reusing as end posts.
An in-progress pic of the new gate and fence below. Main posts are boxed 2x12s PT, painted with spray-on undercoating from ground level down, faced with wire mesh for the masonry from ground up. Couple of pieces of rebar through the bottoms to hold it in the concrete better, and also tie the concrete together if I decide to fill the void inside the box with concrete (undecided on that). The faux stones are left over from the water table of our 2018 house build. They'll go to the top of the posts. The stonework for the main columns will be matched with a stoned concrete pedestal base for the end posts (you can see the pedestal form around the end post in the far right of the picture).
Digging note of interest: I pondered how to dig the post holes for both the boxed 2x12s and the 6x6s. I don't have a post hole digger for my tractors. My backhoe bucket would have removed more dirt than I wanted and would have required more concrete. Instead, I used my HF Predator auger with 6" bit. For the larger posts, I augered nine holes in a 2' square and shoveled out the dirt. Worked well. For the 6x6, I augered one hole and widened it to spade-width (about 12" on all sides) with my shovel. The auger made the labor shorter and much easier. Not as easy as a big auger or a narrow backhoe bucket, but perfectly acceptable for casual DIY work.
   / Rebuilding property entrance fence and gate; post-mortem on 25+ year old 6x6 PT posts #2
Gonna be a fun project. The gates look really nice!!!
   / Rebuilding property entrance fence and gate; post-mortem on 25+ year old 6x6 PT posts #3
That's gonna look nice! :thumbsup:
   / Rebuilding property entrance fence and gate; post-mortem on 25+ year old 6x6 PT posts #4
You gonna do a motor for opening?
   / Rebuilding property entrance fence and gate; post-mortem on 25+ year old 6x6 PT posts #6
If it is shut and raining, your wife will want a remote. I have to keep mine closed due to unwanted pests.
   / Rebuilding property entrance fence and gate; post-mortem on 25+ year old 6x6 PT posts #9
Yes, before the gates I lost a pile of scrap metal. Didn't mind that, but they also took a mower deck and tiller for a garden tractor. Did not take the tractor. Tractor is now worthless. And they took down the round pen panels I had around an area for my horse to get to green grass. Stacked them in front of my barn and left the horses to roam free about 100 yards from highway. Did not take the panels, I think because they were 16 foot and can not haul in most pickup beds.
   / Rebuilding property entrance fence and gate; post-mortem on 25+ year old 6x6 PT posts #10
Unlikely. It's open almost all the time.
I kept my gate open for 15 years and never had an issue. But my wife kept after me about locking it up because it would only take that one time that somebody came in and did something. Now that we have the gate opener in and it's working properly, I'm happy to have it. There is a more secure feeling knowing that the gate is closed all of the time.
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
2011 International DuraStar S/A Refer Truck (A47477)
2011 International...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
Volvo EC330 BLC Excavator (A54865)
Volvo EC330 BLC...
New CFG 680 Skidloader Pounder (A50775)
New CFG 680...
