Harbor Freight quick hitch
/ Harbor Freight quick hitch #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I may treat myself to a Harbor Freight quick hitch this afternoon. Locally only $110.
One Woodland Mills video mentioned that it is compatible with the HF quick hitch.
Got a guy coming to look at the old MacKissic shortly. Sent him my computer files already and found paper files and even a little grease zerk.
How will the quick hitch affect the PTO shaft on my Frontier bush hog? Might it be too short?
Ralph
/ Harbor Freight quick hitch #2
Ralph
Depends on how (long) it was cut originally....
Dale
/ Harbor Freight quick hitch #3
You can buy PRO extensions pretty reasonably. When I added Pat's Quick Hitch I learned my PTO shaft was WAY too short. In fact it had in reality been too short for as long as I'd owned the tractor. I opted to get a new PTO shaft and cut it myself. Mine would have probably taken two or three extensions to get right and I didn't like the idea.
/ Harbor Freight quick hitch #4
You'll need to make new pins for the draft arms. The ones that come with the QH are 20mm and your draft arm swivelly balls are 7/8"...a difference of 2.2mm. You'll also need to fabricate, modify, or purchase a new top hook which will move the hook centerline back about 1".
Discovered you can get 4" PTO extenders. Might be what I'll need for my bush hog. Can get one online for about $30-50.
Ralph
Hmm. The HF Quick Hitch adds around 4 inches.
Another possibility for the bush hog is to get one of those quick PTO adaptors. Wonder how many inches they add. Would have it easier to connect that heavy bush hog PTO.
VERY expensive.
Ralph
/ Harbor Freight quick hitch #7
Check your pto shaft first, you may not have to do anything.
My length was fine when I added my Titan quick hitch. But I never had to cut my shaft down previously either. It had enough travel to be safe both with and without the quick hitch.
/ Harbor Freight quick hitch #8
Might be worth the drive to the Agri Supply in Petersburg, Virginia. Their quick hitch comes with the extended hook and they will also have a shaft extender in stock. I don't have their part number for the extender but I bought mine when I bought the quick hitch and it has worked fine.
My brush cutter has the floating top pin. To use the quick hitch on it I just use one bolt on the top hook and raise it up so it can pivot but can't come off the pin. My finish mower requires the fork type adapter which is also available at Agri Supply.
Careful running shaft driven implements on a QH that you don't lower the 3 point too far. The cross bar on the QH will contact the shaft and ruin the cover pretty quick.
/ Harbor Freight quick hitch #9
Also want to pick up enough cat1 to cat2 and cat2 to cat3 bushings for all your implements.
/ Harbor Freight quick hitch #10
I was almost decided to get the QH from HF. But I am leaning towards the C1 QH from Tractor Supply. Don't mind paying a little more if the quality is a step up. I believe it is made by the same company that makes the SpeeCo but sold under another brand. They look identical. The good thing is Tractor Supply will deliver to my local store for free compared to Agri Supply shipping it to me for $50. Saves me from having to drive 100+ miles to pick one up.
Picked it up this morning. First trip here to HF. Had been to the one over the mountain a couple times.
Found bottom to top link dimensions on the WC46: 13 and 15 inches. Can check position of top hook on the QH.
One some implements in the past, I've had to set the top link at a different length. I'd think this is a problem in connecting to some of them. Probably only the bush hog whose top link has to be set to have the movable gizmo on the top in the mid point of its run.
Ralph
/ Harbor Freight quick hitch #12
My rotary cutter and flail mower were like that, I had to change the length of the top link from one to the other. Mostly because of the way the flail mower sat on the ground. But I'm fixing that during my makeover of my primary tractor. I added "top-n-tilt" and a third set of ports for my grader blade (swivel). With a top link cylinder, that hassle will be over.
By "gizmo", do you mean a flexible link? I added the link that looks like a cowboy spur since my rotary cutter didn't have one. It allows the top link to flex if the rear of the cutter goes over a rise. It helps the flail too since I run the rear roller on the ground.
There's a sliding thing, about 4 inches or so slide, on the top link for both the Frontier and JD LX-4 bush hogs. Forgotten what it is called.
Ralph
Got the HF QH. Had to adjust the top hook to it lowest position to get close to the 15" the WC46's top link is. All my other implements' top links are about 17" up.
Think I'm gonna get this thing: Amazon.com: Hildirix Versatile Quick Hitch Adapter Inside Width 2-13/16?Used to Adjust Top Link Bracket Movements for Category 1 Quick Hitch: Home Improvement It's a hitch adaptor. This one is $46. There's a Speeco one for only $29, but it is out of stock and has no adjustment. The $46 one has 2 holes where it affixes to the QH. With this, I'll have to get off each time to attach the top link, but I'd probably have to get off to adjust the length of the top link anyway.
Don't relish having to move that top hook with its 2 bolts. Think it's gonna be too high for the WC46 at its lowest position, too. We'll see when the WC46 gets here, supposedly tomorrow.
Just thought of another option. Wish I'd thought of it before ordering the adapter. Could use a top hitch pin instead of those 2 bolts on that top hook. May try it tomorrow on the WC46. Could send the adapter back; I guess. Probably not worth the shipping.
Ralph
/ Harbor Freight quick hitch #15
not sure how tall the top hook is on yours, but you don't need or want the top pin bearing in the bottom of the hook since your bottom pins are designed to do the heavy lifting. you only need enough of the pin in the hook to hold tension. I suspect you wouldn't have an extra 2" of vertical height to use all of your stuff at one setting though. many years and a different tractor prior to having a quick hitch I made a 3ph drawbar for trailer moving. I used some random angle scraps for the vertical legs and ended up with a hole at about 15-3/4" above the bottom pin. when I made my ballast I made it to about 15-1/2" just to make sure it wasn't bearing. there's a post on here about quick hitches and someone shared a standard sheet showing that it is supposed to be 15" top to bottom pin for cat 1 & 2. seems like it's not a regularly followed standard though. I'm going to work this spring to make sure all of my attachments will work to the 15" spacing.
/ Harbor Freight quick hitch #16
Ralph
That's the one I was talking about. I got mine from HF but had to order it. I seem to remember it being in the $20 range. That was about 12 years ago.
I modified mine. I cut off the two extra holes on the yoke side. Then used that end on the top link. I mounted the "spur" end to the QH. I made spacers out of PVC pipe to center it on the pin. It worked for years that way. It's always shown on the implement side which seems silly to me. I was able to back up to my implements and go. The only time I had to get off the seat was to connect the PTO on the rotary mower.
/ Harbor Freight quick hitch #17
Ditto on this. Make all your attachment fit the QH. I only had to change one but mine are old. Seems like the old ones are more "standard" than the new implements.
By the way, that ANSI standard someone posted a while back is all wrong. It doesn't match up to any of my tools. :rolleyes:
/ Harbor Freight quick hitch #18
I skipped ahead but a few things come to mind that I learned.
On my old 47 ford 9n, I put an overrunning clutch on the PTO shaft and it made the difference up perfectly for the HF quick hitch setback.
My Kubota with HST doesn’t need an overrunning clutch though.
One of the best mods I did was weld a piece of receiver extension tube(also from harbor freight inside the quick hitch under the horizontal piece.
Not center. That could get in contact with the PTO shaft on a hill or ditch. And not too close to the vertical piece. So you can get the pin and safety clip in the standard spacing hole(s).
Lets me throw a receiver hitch, vise, winch, Pintle hitch, or drawbar hole hitch on as needs dictate.
I use quick release pins instead of bolts for the hook.
I extended my hook also.
The top hook adaptor (stirrup looking thing) from harbor freight was cheapest (25 bucks)but had to order it and has worked fine for 5 years now. It came quick from California though. Within a week.
Seems like I even used a coupon code for 20% off back then.
Sent the new owner of the MacKissic a URL for a $5 pin to convert the Mac cat. 0 to cat. 1.
Top only needs maybe a couple zip ties.
Ralph
UNUSED WOLVERINE SP-15-84W 84" SNOW PUSHER (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
INOP/NON-RUNNING 2007 International 4400 Day Cab Truck, VIN # 1HSMKAZN77H451431 (A61165)
INOP/NON-RUNNING...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
International 10ft 8 Way Grader Blade (A64047)
International 10ft...
