Concrete thickness for gravel driveway entrance
   / Concrete thickness for gravel driveway entrance #51
Rebar at the bottom provides the most tensile strength
Does not....rebar at base of slab is absolutely uselesss and provides minimal tensile strength. Thats just throwing it on the ground and wasting all that steel.
   / Concrete thickness for gravel driveway entrance #52
INSIDE the lower part, an inch or two up, is good. Rebar lying on the ground with concrete poured over is a waste of rebar.
Bruce
   / Concrete thickness for gravel driveway entrance #53
For tensile strength, concrete below rebar adds no strength. You just need enough concrete around bar for bonding. I have seen many structures with no concrete under rebar due to delamination
2001 BOMAG BW141AD-2 SMOOTH DBL DRUM ROLLER (A52707)
2001 BOMAG...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2011 Ford Explorer SUV (A53424)
2011 Ford Explorer...
Hose Reel with Hose (A53425)
Hose Reel with...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
