How tall is an L or MX with a cab
   / How tall is an L or MX with a cab #11
That good info am in the market for a L4060 and was wondering of the hight also so it will fit my 8foot door. Also like to no what the top speed you can get whit a L4060 just to no am doing snow removal just like to see how much it be faster then my B2650
My L4060 fits through my 8' garage door, but I had to make a slight modification to the electric door opener. Just cut off part of a bracket, no big deal.
In real life on flat pavement you can expect 16 mph. Down a steep hill 17mph, up most steep hills in my area 9 mph. I rode mine a lot.
   / How tall is an L or MX with a cab #12
Advertised at 16mph which I do get on paved surfaces. I have. 7 snow pusher and so far have had no trouble pushing the snow we致e gotten.
   / How tall is an L or MX with a cab #13
Am looking to get the Nokian tires but not sure what the hight going to be . If see the lot now on kubota and are avalible whit the dealer the coast are wow are they real good tire do.
   / How tall is an L or MX with a cab #14
I can hit 14, maybe 15mph downhill on my L4060hstc. Pretty sure tire size is correctly programed in, but haven't verified the dash with a GPS.
I'm in Colorado & suffer from a 20% HP no oxygen penalty. Sitting over 7,000lbs with loader, bucket/forks,, loaded tires & an implement. Up steeper roads I'll drop below 8mph. On flat roads it's generally around 13mph. Pretty sure the governor is the limiting factor downhill, not HP. Never been bold enough to try in neutral.
It's annoyingly slow on the road at times. Wish I had a L6060, but it wasn't in the budget. I don't regret getting the L4060 though.
The various grand Ls come with increasingly larger tires depending on the model, not to mention R1/R4 tire size differences. Frame is the same, but front axles & engines change a bit. Bigger tires will mean more speed if the engine RPM is the same & you have the HP.
   / How tall is an L or MX with a cab #15
Im looking to go whit turf tire on my L4060 was going to nokian but after reading a few place looks like the turf tire are what every one like . On my b2650 i have G4 and fin them no that good in sow and ice .
   / How tall is an L or MX with a cab #16
I would prefer Nokian tires, but could not find the size or dealer to get them from. Most of my "must do" tractor work is plowing.
If you haven't already, you should look into the new R14 tires that may even be a Kubota option. I don't have any experience with R14's, but they look like a good compromise tire.
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2019 Dodge Charge Sedan (A55853)
2019 Dodge Charge...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
2016 Freightliner M2 106 Altec AM50 50ft Bucket Truck (A55852)
2016 Freightliner...
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
2014 Freightliner M2 106 Ambulance (A55852)
2014 Freightliner...
