   / Your last generator Maintenance Run #4,911
Sorry, but i have knowledge about soft start units for that small of motor. You could contact hyper engineering and ask them. Their tech guys are real helpful
   / Your last generator Maintenance Run #4,912
geez, I could sure use a soft start module in the morning.
Mighty stiff getting going...;)
   / Your last generator Maintenance Run #4,913
Ten days ago ................
   / Your last generator Maintenance Run #4,915
Ok, I thought that you were just missing a - or/ between Florida and Ma. :laughing: a fairly common situation here in the n/e.:thumbsup:
   / Your last generator Maintenance Run #4,916
The neighbors generator woke us up this morning @ 5:30 and I was on battery backup nice & warm under my electric blanket :)
Got dressed and went downstairs to check the SCP (system control panel) battery was at 24.2 volts with wood furnace fan running.
Shut the fan off so system would not shut down due to low battery voltage, went into garage and started the Honda EU2000i then switched the fan over to gen power.
Then proceeded out to power house to start the MEP-952b 28 volt military generator. Heated the air for a minute or so then cranked it over.
After cranking for several seconds it started. Let it run for a minute then connected it to batteries. Initial current draw was 180 amps at 28 volts.
Went in the house & hit the button on the coffee pot.
After the coffee is on things don't seem so urgent.
Power back on at 7am.
Guess this was a good prompt to resume working on setting up the AGS (automatic generator start) which is mounted but waiting on me to devise a wiring plan.
I was working it it last spring but stopped because I had to order relays and several spools different colored of wire to identify circuits.
If the AGS was operational the generator would be started automatically based on battery voltage and I wouldn't have to get out of bed.
Wife wants to know how to operate the system so I need to get my butt moving.
90cummins:)
this turned out well plus enough room for me to put
a barbecue grill here
Good looking corner there d :thumbsup:.
Rgds, D.
   / Your last generator Maintenance Run #4,918
90cummins:)
Why not replace all that complexity with an MEP diesel gen (or Amazon.com : Westinghouse WGen95DF Dual Fuel Portable Generator-95 Rated 125 Peak Watts Gas or Propane Powered-Electric Start-Transfer Switch & RV Ready, CARB Compliant : Garden & Outdoor ) and a $79 breaker lockout kit?
Power for the whole house and be done?
My inverter easily powers the entire house including the deep well pump however I would need to run one of my diesel DC gensets to maintain the backup batteries after a couple hours when my wood furnace is operating in the winter.
During the heating season my wood furnace is my primary heat source and power consumer. The fan motor is a new High Efficiency model and consumes 236 running watts and operates 24/7. My batteries do not have the capacity to run this and other essentals thru the night.
The fan motor runs constant when the furnace is supplied with a steady supply of wood however it cycles off and on when the furnace starts to cool. It is this scenaro that gives the Honda EU2000i absolute fits.
A soft start module would hopefully allow the Honda EU2000i to easiy start the fan motor while also powering minimal lighting (all LED's) and 2 bedrooms with electric blankets.
Transfering this load and several other small loads such as the living room tv and the bedrooms and electirc blankets to the Honda would minimize load on the inverter batteries allowing the inverter to support the house thru the night without the need to operate the diesel generator.
90cummins
This is an interesting scenario/problem.
The attraction for something like your Honda is quiet + low fuel consumption vs. steady-state loads. If you talk to Hyper or others, let us know what transpires....... you are using wood, but obviously this furnace-fan issue applies to people using other combustion sources.
Rgds, D.
   / Your last generator Maintenance Run #4,920
price has dropped on the Westinghouse by at least 100 bucks, 950 is a good price for that size gen, which is same one I have. Price was up to 1100 and more for awhile.
and you need a few more parts than the interlock kit. Going to run mine in the noon sun today and see if the little propane tank will do it.
Selco V5-HD Vertical Hydraulic Baler (A55851)
Selco V5-HD...
16ft Gooseneck Livestock Trailer (A54865)
16ft Gooseneck...
2018 Ford F-550 Flat Bed Truck, VIN # 1FDUF5GTXJEC35552 (A54865)
2018 Ford F-550...
UNUSED HYD POST DRIVER (A52706)
UNUSED HYD POST...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
