How tall is an L or MX with a cab
   / How tall is an L or MX with a cab #1
BeezFun
IL
Kubota B2710
I'm in the market for a used tractor, probably an L or MX with 50ish horsepower. I can't find the height of this size tractor with a cab on it. I have a 10' door, I'm thinking that might be a bit close. Does anyone know how tall tractors like this are with a cab?
   / How tall is an L or MX with a cab #2
   / How tall is an L or MX with a cab #4
Cab top on Grand L 4060 with R-4’s.
Thanks much, nothing beats a tape measure for a real number. I'm actually kind of surprised it's so low. I have this rinky dink little JD 738 with a soft side cab on it and it's 7'-2" so I can't get it in my garage bay with a 7' door. I always wondered why they made the cab on such a small tractor so tall that it won't fit a standard garage door.
   / How tall is an L or MX with a cab #6
If your shopping Grand L at least 50hp you’ll be into 5460 or 6060. Both may be a little taller than mine. Also, if your using R-1 tires it will be taller.
I'll probably end up with an MX, they seem to sell a little cheaper and have everything I want. I actually don't need a cab but so many of the larger Ls come with a cab I'll take one if it's a good deal. I'll either get turfs or industrials, I don't need Ag for anything.
   / How tall is an L or MX with a cab #8
I have a MX6000 Cab and it does fit in a 10' door with a few inches to spare. I have R4 tires.
   / How tall is an L or MX with a cab #9
That good info am in the market for a L4060 and was wondering of the hight also so it will fit my 8foot door. Also like to no what the top speed you can get whit a L4060 just to no am doing snow removal just like to see how much it be faster then my B2650
   / How tall is an L or MX with a cab #10
My L6060 with cab makes it inside my 8foot door with a little over an inch to spare. R4 rears are at max pressure. If I remember the specs, to ROPS is a little taller - unfolded that is.
TANK MANIFOLD (A55745)
20-Ton Hydraulic Bottle Jack (A55852)
20-Ton Hydraulic...
5' DISC HARROW (A57192)
5' DISC HARROW...
(INOP) FORD 600 TRACTOR (A57192)
(INOP) FORD 600...
UNUSED SDLANCH SDLGC80 GOLF CART W/ TOP (A57192)
UNUSED SDLANCH...
Crate of Motor Oil & Transmission Fluid (A56469)
Crate of Motor Oil...
