GC2410 Hood
/ GC2410 Hood #1
WANNABE1
NH
Massey Ferguson GC2410
Hi all, I lifted my hood the other day to get the battery charger off and when I tried to lower the hood to close it it came off at the bottom where it was hinged, was wondering if it is welded on or if it is made to be removable but either way I could use some guidance in how to reattach it.
Thanks all
Chris
/ GC2410 Hood #2
For what it's worth, my 2310's hood is bolted on, both on the underside of the hood and at the hinge points on the frame, using a U-shaped tubular sub-frame.
/ GC2410 Hood
Thank you IrvingJ
That is what I was thinking too but then thought that perhaps they made these to be easily removed for easier access if needed.
/ GC2410 Hood #4
Here's how mine's bolted -- 4 bolts (I should say, nuts -- they're on studs that protrude from the hood) on the under-hood brackets, two hinge bolts down by the black grille. They probably use an elastic stop-nut on those hinges so it can still move but the nuts stay put; sounds like one of yours may have come off.
Where you at in NH?
/ GC2410 Hood #5
Good question-I will have to take a look a bit later.
/ GC2410 Hood #6
2010 GC2400 hood
2 bolts in from side separate hood from tractor 2 bolts from underside sep hinge.
attached is page 37 of service manual (eng removal section) showing removing 2 bolts for hood.
would have attached actual pdf page but could not, can not get graphics any better sorry
/ GC2410 Hood
2010 GC2400 hood
Thank you, I think this is the set up I have, so I am thinking my bolts came off or snapped, now that I know a little more of what I am dealing with thanks to your great photos I can proceed in repairing it.
/ GC2410 Hood
Where you at in NH?
View attachment 682891 View attachment 682892
Yours set up is different than mine, the comment below with pictures is what mine looks like. Thank you for taking the time to show me all that
I am in Mason NH, Home of the famous Parkers Maple Barn.
/ GC2410 Hood #9
prob the differences between gc2300 and gc2400 series.
don't have a 1700 series in yard right now but think it uses setup similar to the 2400 pics I posted but don't hold me to that.
edit:
if hinge is broke for gc2400 hinge part number is 6254355M2
/ GC2410 Hood
edit:
Thanks again, I will have take a better look at the hood hinge and check it out, thanks to you and others I now have an idea what I am dealing with.
/ GC2410 Hood
edit:
I went and took a peek at the hood what I see is the hinge is bolted to a plate that is welded to the hood and that plate snapped off at the welds, so I think my options would be to get someone to weld it back together or maybe drill & bolt it back on so that won't happen again, thoughts?
/ GC2410 Hood #12
was wondering about that.
if weldable I would choose that but I have not had mine off so I cannot see thickness of area.
/ GC2410 Hood
if weldable I would choose that but I have not had mine off so I cannot see thickness of area.[/QUOTE
Think I need to take a welding class ;)
/ GC2410 Hood #15
This is exactly what happened to my GC2610 about five years ago. I welded the reinforcing piece back on the hood and made sure it was well done. I then masked of and repainted in black the portion of the hood level with the grille and below it. Looks fine. P.S. I drilled several holes in the small piece and button welded them to the hood as extra reinforcement.
/ GC2410 Hood
Thanks for the tip!
/ GC2410 Hood
Thanks for the tip!
/ GC2410 Hood #19
You're right -- I forgot that the 2400-series was the first real change to the GC designs. Mine's one of the last 2300-series tractors. Wish I had your gauge cluster - the one that has a single plastic cover! (Mine's a real PITA to keep clean while blowing snow, with the separate teensy gauges...)
/ GC2410 Hood
This is the first tractor I have owned, I guess I am happy to hear my cluster gauge is not an issue! That would drive me nuts especially with tiny gauges. Maybe you can create a cover to protect it, you know the saying Necessity is the mother of invention, might be some idea that is simple enough to do.
