Problem with pictures
/ Problem with pictures #1
Bavarian
Winnipeg
Massey Ferguson 1759
For quite some time, I have issues to see pictures that other members posted.
I always use the same device and I didn't change any settings.
Has anybody else the same problem?
The attached screenshot is an example for what I see. Maybe an Admin can chime in.
/ Problem with pictures #2
Pictures usually initialize off the the extension is (JPG-PNG) and so on if URL for graphic is correct...
What is your device, and what browser/app are you using to access forum?.... IF you device will run the CHROME browser and you are not using it, you might try it....
Dale
I'm using a Samsung S7 and the TBN app. It worked before. That's why I'm wondering why it doesn't work all of a sudden anymore.
/ Problem with pictures #4
I found that clearing the phone cache, and then app cache and finally force stop the app. Open it back up and then I can see posted pictures again.
/ Problem with pictures #5
If all else fails delete the TBN app and reinstall it. That fixed my issue.
Thanks guys. Deleting the app and reinstalling helped to solve the problem. I was checking for an update but there was nothing available.
/ Problem with pictures #8
What Mr. Sickeys said...
For Android: Go to Settings...select App Management...select Tapatalk app...select Clear Cache...
Takes less than 10 seconds and typically resolves any issues I've had seeing photos.
2022 EZ-GO ELITE...
2020 FREIGHTLINER M2 4X2 S/A 26FT CDL REQUIRED CURTAINSIDE BOX TRUCK (A67148)
2020 FREIGHTLINER...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2006 Volvo VNM S/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM S/A...
Wooden Chair (A64557)
2007 FREIGHTLINER COLUMBIA TANDEM AXLE 6 X 4 TRUCK TRACTOR (A67147)
2007 FREIGHTLINER...
