Hole Digger Solution
/ Hole Digger Solution #1
Rhombus
Kubota RTV 1140
I bought a 60 acre farm recently and I really don't plan on doing any traditional row farming so I was thinking a Ventrac might be a good solution for me. I am just about ready to pull the trigger but I need to dig fence holes for the estate and holes for an orchard that I am going to put in. If I cant find a ventrac solution I'm going to punt and just get a traditional tractor, probably a Kubota Grand L60 and be in debt for the rest of my life. So do any of you have a Ventrac based hole digger workaround? From my research it seems that at one time Ventrac had a post hole digger attachment but not anymore.
Thanks much!
/ Hole Digger Solution #2
I’m sure a fabricator could make one.
You have a power source and a hydraulic source
/ Hole Digger Solution #3
I don't see place on 60 acres for a Ventrac I think a cut may suit your needs better it will mow and with the proper attachment do everything you need to do. FEL and a Backhoe would even be better. After you get your head above water in a while get a big zero turn to mow with...... jim
/ Hole Digger Solution #4
If you have no plans to farm, you might take a look at a CTL (skid steer) and see what you think. They are the swiss army knife of machines.
/ Hole Digger Solution #5
I don't see many trying to mow with one, after a couple times if you get a mower you wouldn't have any grass to cut..... jim
/ Hole Digger Solution #6
Probably not great as a finish mowing platform, but for brush control and reclaiming ground they are awesome.
Do you think its just too big for a ventrac? I have about 8 acres of lake and muddy shorelines that I doubt a big tractor can navigate so I was also attracted to the ventrac's low pressure wheels. Please forgive my ignorance, but what is FEL?
I hear you. I'm starting to think that no matter what i am going to have to have two machines. Thanks!
/ Hole Digger Solution #9
FEL = front end loader
/ Hole Digger Solution #10
How many acres are you fencing, and is it hilly, stony ground? Are you planning typical 4-5' wire fence with steel or wood posts, or a 5 rail board fence?
In either case a small older 15-25 HP tractor with a Post Hole Digger for $8-10K and maybe a 4-5' brush cutter would be a good start. then get a larger L series or similar for the rest of the work - and yes you need two tractors, and you came to the right place to let us spend your $.
/ Hole Digger Solution #11
I'd agree with those who suggest a 40hp or so CUT for the 60ac based on versatility and experience. (Kubo 4200 :thumbsup:) IMO an L60 is a few sizes big, esp for the orchard.
Compare dual wheel and higher hp options for Ventrac. Low height and maneuverability may be a boon for orchard work. There are some awesome add-ons and support is pretty awesome.
Tractor has advantage of more used &/or local 3-PH & SSQA attachment availability. Attachments can be bought used and re-sold if they outlive their usefulness. Advantage tractor.
I suggest getting the right machine for the long haul. The post/planting hole part ought to be easy either way.
/ Hole Digger Solution #13
Thanks much!
Struck sells a remote hydraulic auger kit. It is their NH3A. (struckcorp.com)
/ Hole Digger Solution #15
Has anyone ever found specs for the Ventrac hydraulics? In order to think about building a hydraulic auger? I'd put it on the 3-point hitch.
/ Hole Digger Solution #16
We have six tractors and two skid steers and still run out at times.
three headed Native American statue (A61569)
three headed...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A61567)
2014 Jacobsen AR3...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
WHEEL BARROW (A62131)
