What do you do with your Instant Pot you cant do with a crock pot?
   / What do you do with your Instant Pot you cant do with a crock pot? #662
Well, we did not use the Insta Pot,, or the Crock Pot
I used the Pressure cooker.
We did this as a guess, because it is what we had in the house,
The results would be considered restaurant quality.
I browned a pound of stew beef cubes that had been coated with AP flour. I used some peanut oil in the skillet to brown the meat.
We tossed that, in the pressure cooker, plus;
4 cups chicken broth
2 cups cut up carrots
one cup cut up celery
2 cups water
one box of Zatarain's Dirty Rice
We put it on high heat, then adjusted to slight rock of the rocker for exactly 3 minutes.
Everything came out perfect, the rice was cooked, the "Dirty Rice" seasoning was exactly what was needed.
It was one of our best pressure cooker meals. :eek:
I guess the Insta Pot would do it, but, I would not know how long to cook it?? :confused:
   / What do you do with your Instant Pot you cant do with a crock pot? #663
Sounds tasty. How did you depressurize the pressure cooker? Let it cool, or cold water quickly?
   / What do you do with your Instant Pot you cant do with a crock pot? #664
We just Google instant pot recipes. We use the recipe as stated and then change it to suit our tastes if needed next time.
   / What do you do with your Instant Pot you cant do with a crock pot? #666
I hit it with cold water, it STILL took over one full minute to depressurize,,
   / What do you do with your Instant Pot you cant do with a crock pot? #668
I do the same but without printed copies there is nowhere to make notes of those changes :shocked:
I need to start printing the better recipes and make notes on the paper.
   / What do you do with your Instant Pot you cant do with a crock pot? #669
He was using a regular presssure cooker (as used for canning).
He is using an Instant Pot. That is the way mine looks like.
   / What do you do with your Instant Pot you cant do with a crock pot? #670
I know how to use both an instant pot and a pressure cooker. :laughing:
I was asking which method he used to cool it. :laughing:
2016 Ford F-450 Crew Cab Kanpheide Service Truck (A49461)
2016 Ford F-450...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
